6th gen swap / info on mounts?
I've tried the hybrid forum but got no responce, guss I'll try my fellow 5th and 6th gen owners.
I'm putting in a 99 SI engine in my 97 hatch. What mounts will I need? Any suggestions for upgraded parts? I have been looking at these, please, I need opinions. I've been told I need the 99-00 Civic SI rear tranny mount and I'm only getting some 2000 Integra mounts with the engine, will any of these mounts work?
This is the A/C mount
Re: 6th gen swap / info on mounts? (6ghatch)
Re: 6th gen swap / info on mounts? (Trey)
You can use two front lower mounts off the integra. Use ur stock upper tranny mount and the top upper apron on the driver side. You will need a 99-2000 Si rear motor mount bracket and the mount that bolts to the upper driver side block. The stock rear mount that bolts to the chassis is hella weak so you may want to go with either prothane inserts which will raddle like a bitch or the stock Si mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey »</TD></TR><TR><TD CLASS="quote"> http://www.jspectuning.com/6gen/
Anyone know where else this guide exists? jspectuning seems to no longer exist. Thanks.
- wei
- wei
get the place racing driver side and upper tranny mount. Then get the back mount, AC bracket mount and lower tranny mount from honda...
just getting started
06-09-2008 04:50 AM
jaydm ferio
10-26-2004 08:06 PM
swiftstyles
11-19-2003 04:58 PM
