D15B7 IDLE
Old 11-17-2016, 12:11 PM
Asaf's Avatar
Icon5 D15B7 IDLE
Hello
I have Honda civic d15b7 engine 1.5L
and I wanted to know why my idle is rising in N gear ,or P gear ,or R gear ,to 1250RPM when the car is already at working temperature.
when the car is cold and I start it the idle is at 1200RPM and playing up and down between 1100-1200 RPM.
no error code at all.
There is a small black smoke coming from the exhaust and a very hard smell of gas specially when I hit the gas
please I need some help how to fix it in my opinion I think it’s the FITV that need to adjust.
What do you think?
Thank you
Old 11-17-2016, 02:46 PM
mk378's Avatar
Default Re: D15B7 IDLE
Did you just obtain this car?
You need to resolve the rich running / black smoke first. Likely someone has tampered with the idle system to keep the engine running (poorly) while it is making all the smoke.
Check that the CEL works. The light should come on for 2 seconds when you turn the key on but don't start. With the test jumper in place, it should light up steady while the key is on. If it never lights up at all, someone has removed the bulb or just let it burn out.
Old 11-19-2016, 02:33 AM
GDD Member
slomofo's Avatar
Trade it in for a BMW, you'll be better off.
Old 11-19-2016, 06:24 AM
White_EG1's Avatar
Make sure it's a 5 series tho...
Yeah like Mk said, but I'd fix the idle issue. Clean out the IACV first If that doesn't help clean FITV and adjust the plunger all the way down.
Now you can roll around with a steady idle while fixing the running rich issue, speaking of which are you sure you aren't seeing a blueish tint in the smoke?
Pull the spark plugs, see black soot on them? If you are really running rich there should be a strong smell of gas on them as well.
Old 11-19-2016, 09:05 AM
Hysterically Calm
TomCat39's Avatar
Running rich sounds like injectors stuck open.
A noid light will tell you if the injectors are receiving the correct pulse signals. If always on, there is an electrical problem. If all pulse as the car is running, then it's a mechanical issue with gummed up injector(s). A quality fuel injection cleaner will clean them up.
Berryman's B-12 Chemtool is a high quality one.
As well as if you can find Wynn's Power Charge, that is a quality fuel injection cleaner.
Old 11-19-2016, 05:26 PM
Former User's Avatar
What car and ECU?
Old 11-19-2016, 08:16 PM
GDD Member
slomofo's Avatar
Originally Posted by RonJ
What car and ECU?
Why RonJ? Why do you do this?
It's a 92-95 DX or LX ffs.
Old 11-19-2016, 08:20 PM
The engine could be installed into a multitude of different cars, including an 88-91 Civic with an OBD0 ECU. As you know full well, car information is crucial to understanding any tech problem. Is the D15B7 completely stock otherwise?
Old 12-31-2016, 12:34 PM
Asaf's Avatar
Icon5 Re: D15B7 IDLE
Question about the FITV part
Please check the photo added.
Thank you
Old 12-31-2016, 02:43 PM
Hysterically Calm
TomCat39's Avatar
Coolant and as can be seen in your photo, that is some serious buildup of garbage.
Old 01-01-2017, 05:23 AM
Asaf's Avatar
I understand and for the knowledge the coolant circulation in this FITV is from throttle body pipe down to the FITV pipe or otherwise?
Old 01-01-2017, 07:36 PM
Hysterically Calm
TomCat39's Avatar
I believe it's otherwise. I believe the coolant flows from the head, to the FITV pipe, passes the wax plug to flow through the throttle body to travel through a pipe to the IACV.
Old 01-02-2017, 06:55 AM
Asaf's Avatar
Also I wanted to know bad FITV function can cause running rich? (the air mixture is not accurate)
Old 01-02-2017, 07:36 AM
mk378's Avatar
No it will not. Like I said earlier in this thread, you need to fix that first.
Old 01-02-2017, 07:57 AM
Asaf's Avatar
What is the most common thing to check?
Thank you
Old 01-17-2017, 09:51 AM
Asaf's Avatar
Hello
I need to know please if I want to disconnect the kick down cable from the throttle body but also to save the adjustment settings can I do it?
There are 2 bolts holding the cable 1 from the right side and 1 from the left side.
Thank you
Old 01-17-2017, 12:45 PM
Hysterically Calm
TomCat39's Avatar
Hello
Thank you
I sent you a PM to help you acquire the Factory Service Manual for USDM D15B7 cars.
The manual will help you with everything you have asked so far and then some.
Good luck.
Old 02-01-2017, 08:21 AM
Asaf's Avatar
Post Re: D15B7 IDLE
Yes I saw it thank you very much.
Old 02-01-2017, 08:26 AM
Asaf's Avatar
Can someone know what is this pipe near the canister?
*see photo added mark with the red circle.
Thank you
Old 02-01-2017, 12:18 PM
mk378's Avatar
This is getting ridiculous. You're not going to show us what's on the other end of that hose?
Chris Falvo
12-16-2013 11:32 AM
gnxpro24
06-06-2011 01:28 PM
MLevinson
06-22-2008 06:35 PM
JDMtype Eg6
11-24-2005 01:44 PM
B18C-RnVA
03-05-2002 08:35 PM
Quick Reply: D15B7 IDLE
