60-80 in .2 SEC....... or Fuuukkkkd VSS? humm
so i drive around and my vtec kicks in and out so i fig that my wiring is messed up
so i get cel21..... so i unplug vtec and my car still runs like **** and my spedo jumps around and the car bogs and then picks up and then bogs the the cel's flash on and off ??
so with vtec i get cel 21
with out i get cel22
with both the car still gets up and falls on its face and then it jumps in and out of vtec
btw my vss doesn't fit in my car right and isnt bolted up but is snug ??? all this stuff is confusing
but im thinking if it was vtec then the car should run fine with it unplugged right?
Re: 60-80 in .2 SEC....... or Fuuukkkkd VSS? humm (xXSilentScreamXx)
all my spark plugs were black but would that cause all this ****?? there like 2 months old but the jackass that put them in there gaped all of them different
well if there all black then that means ur car is running tooo rich. Give more info on your car and what you got in it, + ECU so we can help
Re: 60-80 in .2 SEC....... or Fuuukkkkd VSS? humm (duheeat)
96 ek hb
h22a swap running a chiped p28-obd1
3500 2step
8000 redline
7600 cel shift light
5000 vtec
using h22 injectors and i have a resistor box -
3500 2step
8000 redline
5000 vtec
well i just replaced the spark plugs cause the ngks i had were all gapped wrong and were black, and now my car runs fine except for i don't have vtec but thats because of the wiring
laosbboy
09-08-2003 07:01 PM
Red2001GSR
04-30-2002 07:30 AM
