6 speed b series tranny??
Re: 6 speed b series tranny?? (98greensi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98greensi »</TD></TR><TR><TD CLASS="quote">is there anyone who knows if someone - custom makes a - six speed tranny for a b series???</TD></TR></TABLE>
Fixed. With enough money, anything is possible.
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98greensi »</TD></TR><TR><TD CLASS="quote">is there anyone who knows if someone makes a custom six speed tranny for a b series???</TD></TR></TABLE>
Quaife.
Now, whether or not you have the $20,000 for the transmission and shifter assembly is another question altogether . . .
Quaife.
Re: 6 speed b series tranny?? (Targa250R)
Is there anyone who actually needs a 6speed trans with a B series motor?
Re: 6 speed b series tranny?? (Syndacate)
^^ True. The sport B series transmissions are pretty short anyway, to keep the revs up high as much as possible throughout the shifts. You may be spending some undesirable time between gears if you had a 6th.
be professional
Re: 6 speed b series tranny?? (team1320_k24eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team1320_k24eg »</TD></TR><TR><TD CLASS="quote">do i smell a b2k kit in the works... lol </TD></TR></TABLE>
Have fun with five reverse gears and one forward . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Have fun with five reverse gears and one forward . . .</TD></TR></TABLE>
Nope, engine turns backwards, but tranny's on the other side too, so you'd have 6 forward and one reverse. But the axles would be on the wrong side of the engine! And you'd be spinning the tranny backwards - probably real bad for lubrication.
Think of it this way. If you take a K series, and rotate it 180 degrees, it will now drive the car backwards. If you then reverse the direction the engine's turning, it's going the correct way again.
be professional
Re: 6 speed b series tranny?? (fdavie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fdavie »</TD></TR><TR><TD CLASS="quote">Nope, engine turns backwards, but tranny's on the other side too, so you'd have 6 forward and one reverse. But the axles would be on the wrong side of the engine! And you'd be spinning the tranny backwards - probably real bad for lubrication.
Think of it this way. If you take a K series, and rotate it 180 degrees, it will now drive the car backwards. If you then reverse the direction the engine's turning, it's going the correct way again.</TD></TR></TABLE>
Are you on something? Neither he nor I was serious.
Re: 6 speed b series tranny?? (Egezzy)
i think he got that about right as wierd as it sounds
Re: 6 speed b series tranny?? (Jakester9500)
anyone with a b16 tranny would agree that a 6th gear would be nice on the interstate.
I really hate crusing the hwy at 5k with a turbo car.
Re: 6 speed b series tranny?? (dohcdelsol93)
well if that is the case, why not put the LS 5th gear in the b16 tranny like most people do? just for the highway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Quaife.
Now, whether or not you have the $20,000 for the transmission and shifter assembly is another question altogether . . .</TD></TR></TABLE>
I rather do a k20 6speed swap and still have left over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 »</TD></TR><TR><TD CLASS="quote">well if that is the case, why not put the LS 5th gear in the b16 tranny like most people do? just for the highway.</TD></TR></TABLE>
because i have 20k to put in a tranny
Re: 6 speed b series tranny?? (5_Lug_B)
i want to keep my gearing nice and short but have 6th for a true over drive it would be nice to get the revs down at highway speeds
Re: 6 speed b series tranny?? (HeikDiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel »</TD></TR><TR><TD CLASS="quote">just put a 6sp **** on your shifter. 20 dollar fix</TD></TR></TABLE>
ftmfw
ftmfw
Re: 6 speed b series tranny?? (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">
I rather do a k20 6speed swap and still have left over.</TD></TR></TABLE>
YUPPPS
YUPPPS
UPP AGAIN
UPP AGAIN
