5w-30 or 10w-30?
Re: 5w-30 or 10w-30? (eg_nezay)
Thicker oil is better for older/high miles engines. So, I would use 10-30
Re: 5w-30 or 10w-30? (Westsideboy)
if u have a b18c with abot 40-50 thousand miles on it what weight oil would you people recomend also whats the best recommended brand oil to go with either synthetic or not?
1 Post
Re: 5w-30 or 10w-30? (nextelbuddy)
and why would u recommend the 10 weight over the 05 weight? i am just curious thats all all my other motors were newr with about 10-20k on them so i always used 5w-30 but since this one has about 50k and is also a jdm motor i dont really know what to go with. since ill be running it a bit hard i want the best oil for it
Mobile 1 is a good synthetic but it really doesn't make any difference if you use synthetic or not if it hasn't had synthetic in it from the very first oil change....on the other hand, synthetic is a good oil to use if you do a lot of stop and go drivin'.....
Agreed...but you'll probably find that it won't "wind up" as fast with the thicker oil.
Between those two, I would use 10w-30.
Re: 5w-30 or 10w-30? (99D16VTECCivic)
I use 5-30 Mobil 1 synthetic because my motor is low milage, it doesnt leak or burn and I also read somewhere that it actuallytake less HP to move through an engine than 10/30. Of course were talking a small amout of power. And the main reason I use synthetic... because I'm a lazy piece of **** and hate doing oil changes.
Re: 5w-30 or 10w-30? (ejprimo)
if you are looking for more power, go use 0w-20.
5w-30 is recommended by Honda... why would you use any other weight? :shakes head:
if your motor leaks or burns oil, then fix it and use 5w-30. You are messing your motor up more by using anything else.
[Modified by BCRUZspec, 3:18 PM 3/16/2003]
Re: 5w-30 or 10w-30? (Hatchcrap Ownz J0o)
at very low temps. the oil pumps at 5w..then as the motor warms viscosity moves up to 30..in temp zones where it rarely freeze s it best to use the 10-30w oil s..many race car s use a straight 30w since they re running at high temp s constantly
Re: 5w-30 or 10w-30? (BCRUZspec)
if you are looking for more power, go use 0w-20.wtf?
here's some interesting reading: http://theoildrop.server101.com/ubb/...=001653#000011
Re: 5w-30 or 10w-30? (wizzards581)
5w for temps below 19degrees F and beyond
10w for temps above 19degrees F
so if you live somewhere where its cold right now...get the 5w...then when its warmer get the 10w
Re: 5w-30 or 10w-30? (pdiggitydogg)
S2k maybe??
Evil_Wizard
52
10-28-2002 09:05 AM
