5th poping out
Old 01-17-2012, 08:19 AM
jdm89crxhf's Avatar
Icon3 5th poping out
So u currenty got an eg6 but only problem is my fith gear pops out on highway when it goes under 3k rpm what could this b and how can i fix it its a s20 tranny
Old 01-17-2012, 08:30 AM
jbpnoman's Avatar
Default Re: 5th poping out
First thing's first, check all of your bushings, shift linkage, and transmission/motor mounts. Do you have the stock shift arm, or a short shifter?
Old 01-17-2012, 09:46 AM
jdm89crxhf's Avatar
Ok thanx n i got a short shifter bro
Old 01-17-2012, 10:26 AM
Seagull Management
94EG8's Avatar
Is there any fluid in it? Normally popping out of 5th is caused by low fluid.
Old 01-17-2012, 12:52 PM
jdm89crxhf's Avatar
Any fluied in where bro the tranny yea should b i just added oil today
Old 01-17-2012, 01:04 PM
Seagull Management
94EG8's Avatar
Yes in the tranny. Did you fill it till it started coming back out the fill hole? How far down was it before you added fluid?
Old 01-17-2012, 06:43 PM
jdm89crxhf's Avatar
no i didnt do it that far but i will do that first thing tmw moring but how do u put fluid in the tranny from the head ryt????
Old 01-17-2012, 07:14 PM
Hidenplanvew's Avatar
Lol.. You need a helms... Theres a plug on the transmission.. Make sure you use honda mtf
Old 01-17-2012, 07:22 PM
Seagull Management
94EG8's Avatar
No not from the head, from the fill plug on the side of transmission , or remove the VSS and fill it through the hole (fill plug still needs to come out so you know where the level is either way though. If it's an S20 tranny put cheap 10W30 in it.
Old 01-17-2012, 09:54 PM
jdm89crxhf's Avatar
Ok thanx i will do that tmw morning n see how it goes
Old 01-18-2012, 02:49 AM
Bix VT's Avatar
dang mang, that thur faq suire is hard to pik thru to find a rite up
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/default-%5Bfaq%5D-how-change-your-civic-manual-transmission-fluid-1687986/
bro
vtec25
10
08-15-2005 07:44 AM
InfamousGSR
04-16-2004 05:40 AM
bones_accord
02-16-2003 08:12 PM
ghetto_charged
05-06-2002 07:21 PM
JM Performance
11-22-2001 12:32 PM
Quick Reply: 5th poping out
