5th gen civic is sliggish upon start and sluggish off the fly >>
ok here are the specs >. 95 civic dx 2 dr auto 140k mi. i recently changed the spark plug wires, cap, rotor, flushed coolant, oil, the basic **** > plugs havent been changed but the car sat for the past 5 mos > i have put about 1k mi on it since it went back on the road. when i start it up it startsa but idles very choppy as if to stall. when i give it gas it is fine. also wheni come off the fly like from a light i could floor it and it feels like it is being pulled backwards for about 10 seconds then it pulls nicely.
help would be appreciated.
Re: 5th gen civic is sliggish upon start and sluggish off the fly >> (integra dave)
Gets you a new PCV valve!? New plugs always with new wires/distributor cap. Also reset the ECU backup fuse. You could have gotten water and or rusty internals if it sat for 5 months, so somethings gotta be done in that department. Clean the throttle, lube the accel cable or replace. Other junk that other people are about to list.
Re: 5th gen civic is sliggish upon start and sluggish off the fly >> (f1z1c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1z1c »</TD></TR><TR><TD CLASS="quote">Gets you a new PCV valve!? New plugs always with new wires/distributor cap. Also reset the ECU backup fuse. You could have gotten water and or rusty internals if it sat for 5 months, so somethings gotta be done in that department. Clean the throttle, lube the accel cable or replace. Other junk that other people are about to list. </TD></TR></TABLE> or not
how do you reset the ecu backup fuse? in doing this am i basically resetting the ecu?
thanks
thanks
its not the idle so much as the acceleration >> its sluggish off the fly at times >> i changed the pcv and its a bit better but does anyone think it could be something with the tranny?
Jegacy1396
02-17-2017 08:29 AM
bcumby
12-15-2007 02:36 PM
