5 lug ek, largest tire on stock itr wheel???
Whats the largest tire someone in here has used on the factory itr wheel. As in width and sidewall percentage.
I was looking to not run into any rubbing issues. The car is lowered slightly on apexi n1 suspension.
Re: 5 lug ek, largest tire on stock itr wheel??? (Chris y0!)
enlighten me chris?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">the stock R came with 195s for a reason...</TD></TR></TABLE>
I dont see the problem with running 205x45x16 at all on them. Would you beg to differ and state your opinion why?
Re: 5 lug ek, largest tire on stock itr wheel??? (137)
No dude. I dont have the jdm 16 inch wheels. I have the american itr wheels.
And i dont want to run a pizza cutter 195 reguardless of what the stock itr came with. period.
Risky Business
Yeah because some people have to drive the car year round even in the snow...
My friend runs 205/50/15 azenis on his type R and they are perfectly fine..I wouldnt go any wider than 205
Re: 5 lug ek, largest tire on stock itr wheel??? (colt45)
I was looking into the 205 50 15 azenis.
I think any wider and it would wear incorrectly, and loose handling?
go to the ITR forum and ask people what they think of azenis on stock wheels...
205 azenis = 215 anything else and its too wide for a 6 inch rim. the sidewalls arn't anywhere near square.
like i said, honda put 195s on for a reason, because its the correct size.
Re: 5 lug ek, largest tire on stock itr wheel??? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Yeah because some people have to drive the car year round even in the snow...</TD></TR></TABLE>
i don't see what that has to do with a 195 vs. 205 argument...
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by colt45 »</TD></TR><TR><TD CLASS="quote">Whats the largest tire someone in here has used on the factory itr wheel
I got from this that the widest tire you should run on an ITR is 195...did I read it wrong??
Munkyw3rkz.webs.com
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">go to the ITR forum and ask people what they think of azenis on stock wheels...
like i said, honda put 195s on for a reason, because its the correct size.</TD></TR></TABLE>
i have 215x45 azenis on my R wheels and they are Perfect!
Solbros Owns Me
ITR guys are worse than the EG guys has far as false information goes
I run 205-55-14's on my 5.5 inch Miata wheels. Perfect setup if you ask me.
205-50-15 on the ITR wheels is a great setup. No one should be rocking skinny 195's....unless you're a 14 and want to run HX wheels....cause you have no other choice
Jesus christ. Everything turns into a debate on here.
Im getting 205 50 15 azenis. Its around a 210mm wide.
Ive seen plenty of people run 205 and 195
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by colt45 »</TD></TR><TR><TD CLASS="quote">Jesus christ. Everything turns into a debate on here.
Then why did you ask in the first place
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">I got from this that the widest tire you should run on an ITR is 195...did I read it wrong??</TD></TR></TABLE>
no you read it right. i wouldn't go bigger than 195 on a 6 inch wheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I run 205-55-14's on my 5.5 inch Miata wheels. Perfect setup if you ask me.</TD></TR></TABLE>
but those are R compounds right? right. anything that sticky will feel "perfect", even if its not the correct size for the rim.
just some quotes for you guys:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NewR »</TD></TR><TR><TD CLASS="quote">The majority here suggested that I get the Azenis 205/50/15 for my stock rims and I am a little disappointed with the steering feel. It's a little sluggish for my taste. Does not feel like the RE10 where I just point where I want to go, and it goes there. There is a little delay in the steering with the Azenis.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">as i mentioned in previous thread, get at least 15x7 wheels for 205/50-15 tires.. stock rims are o.k. for stock tires or sticky radials.. its better to invest in wider wheels so you can have stiffer sidewall feel.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flux »</TD></TR><TR><TD CLASS="quote">It is a night and day difference between the Falkens on 15x6 wheels and on 15x7 wheels...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg »</TD></TR><TR><TD CLASS="quote">The key to retain as close to stock turn-in and steering response (notice I never said Exactly the same) is to go to 15x7" wide rims or even 15x7 1/2" for perfect square tire to rim. The vague or squirmy feel (on stock 15x6" rims) is the sidewalls flexing inwards and not being square true to the rim.</TD></TR></TABLE>
I wish you would of posted this the first time I had asked to back up your statement.
the azenis have a very agressive sidewall, ive never experienced the flex they do buy how would I know right... 195's are generally cheaper too.
then you should get a better tire for 10 bucks more a tire...
yokohama avs es 100
<FONT COLOR="red">195/50/15 61 dollars a tire.</FONT>
these are 205's please forgive me chris !!!
yokohama avs es 100
Risky Business
azenis =
avs es100 =
I have a friend that owned AVS, got azenis when the AVS wore down...azenis have 10x better dry traction...
And I have avs on my car now and I slide all over the place on turns...
avs es100 =
better RAIN traction with avs100's and WAAAAAAY LESS NOISE!!!
tread wear on azenis is 200
yokohama is 300
azenis were ****** annoying!
you are prolly running 205's and are experiencing sidewall flex lol
yokohama is 300
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 »</TD></TR><TR><TD CLASS="quote">these are 205's please forgive me chris !!!</TD></TR></TABLE>
keep in mind that a 205 azenis is like a 215 yokohama. a 205/50-15 avs-es100 will work a lot better on a 6 inch wheel than a 205/50-15 azenis.
lol NO ****!!! the azenis stuck out really godamn far... but they protected the lip of my ls mesh wheels plenty o times!!!
