5 Lug on EG HELP
5 Lug on EG HELP
OK anyone on here have a full ctr or itr 5 lug suspension on an EG cuz i'm planning on working with this setup but wondered if it would come in conflict with the type of springs and shocks i use i know most shocks and springs fit 92-95 eg's and 94-01 tegs but they all say except Type-R just wondering any info would be helpful
all i know is that you would want an itr 5 lug. its easier to work with since just about every part from the inegra and 92-95 hatch are compatiable. you can also fine a bunch of info using the search button.. this has been covered befor
Re: 5 Lug on EG HELP (Bonez21)
i got the ITR setup on my EG..but i'm using all ITR components..but if you still want to retain your stock shock setup, then jsut use your stock LCA...and get 92-95 civic suspension if you want to lower your car.
i waz just a little skeptical about what shocks and springs would be compatible with the full itr spindles on my hatch not just the LCA's
Re: (Bonez21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bonez21 »</TD></TR><TR><TD CLASS="quote">i waz just a little skeptical about what shocks and springs would be compatible with the full itr spindles on my hatch not just the LCA's</TD></TR></TABLE>
depending on what Lca's you use that will determine which shocks and springs you will need. if you use civic lca's use the civic shocks and springs
if you use the itr lca then you will need to run itr shocks and springs.
Is this a daily driven car or track car?
Re: (salbaje)
i have ITR 5 lug conversion and i kept all the civics suspension. on teh rear i kept the civic LCA and that allowed me to use my civic shock and springs
Filliam H. Muffman
12
07-04-2006 03:05 AM
philscivic101
11-15-2005 02:38 PM
chameleon
10-09-2002 09:50 AM
