5-Lug conv.
Are the trailing arms in the ITR (USDM 99-00) shorter then the trailing arms on my 99-00 Civic Si?
If so do I need to use a particular lower contro arm? Thanks https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: 5-Lug conv. (NAEBP00Si)
you can use your control arms. If you use the itr's you will need to get itr shocks
Re: 5-Lug conv. (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">you can use your control arms. If you use the itr's you will need to get itr shocks</TD></TR></TABLE>
theres no if, they wont even bolt up. you should be fine. they are the same thing, just bolt it up all you need is the trailing arm. reuse everything else. |
