4x114 brake swap question
There used to be a thread with all the info about getting new rotors for pads for the 96 r brake setup. I searched for ever and couldnt find it - would any one happn to have a link?
Need to replace my rotors and pads.
Re: 4x114 brake swap question (Artificially_Aspirated)
no spacer if possible - i would like a oem like setup.
There used to be a huge topic on this can anyone else find it i try'd!
I am a (Trial User) Army
Re: 4x114 brake swap question (_Creager)
the spacer is like 3-4 mm.... if that is a big deal, then stop now.
There is no direct way to replace the rotors without having to modify something. Using some washers as spacers is the easiest thing. No grinding or dicking around. It will clear stock 4 bolt ITR wheels without any problem.
I upgraded to 11" prelude vtec front rotors with the prelude vtec calipers. I dont like to shave stuff so i used the spacer. I have had no problems with it. Its been over 9 months now.
i actually used some spare washers i had laying around. The ones that i found worked best were actual washers from the subframe. I'll see if i have a spare one so i can take a pic of the dimensions
thenext
11-07-2011 06:39 AM
krnfly2damoon
09-09-2005 06:43 AM
1GreyTeg
04-02-2003 05:14 AM
