4dr EK Window Question
On a 4 door, rear door, the window wing - the fixed window, are they the same on both sides? I cannot find a straight answer. I checked on ordering online and there are two different ones, but the guy who is selling on eBay claims it will work on either side...
Re: 4dr EK Window Question (allmtr)
If you're looking at the back door of a 4 door, there are two windows.. one can be rolled up and down, the other is fixed (sort of wing shaped). Check out the diagram: Part 18/20
http://www.hondaautomotivepart...INDOW
Seems like two different parts, but maybe the guy knows his ****..
Re: 4dr EK Window Question (urname7698)
I personally don't think you can use them on either side, unless you can detach the frame off of the glass.
I don't think you can switch them because the glass is curved on each side. if you put the left one on the right side, it'll be concave instead of curve out, you know? And Honda Automotive Parts lists two different parts numbers for the left and right side, I think.
John Z
Honda Civic (2006 - 2015)
11-16-2006 04:46 PM
