Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: How to Test and Replace Oxygen Sensor
Step by step instructions for do-it-yourself repairs.
41 Primary oxygen sensor heater [easy question]
Car: 1994 Civic Hatch CX
Motor: D16z6 VTEC SOHC
Wiring harness: Stock CX wiring harness [Just finished wiring vtec]
ECU: P28
Question: I'm about to replace a primary oxygen sensor on my car and was wondering if its flipping the code with a wiring issue. I bring this up because i just wired VTEC because that was not wired with the original harness. I may just be overthinking this and the O2 sensor is faulty. Want to double check that i am not replacing a good O2 Sensor but the wiring is just incorrect as the motor was swapped.
I will be following this diagram for removal of old sensor.
Looks easy enough taking off the heat shield and unscrewing the O2 sensor... or is there more than that?
Thanks ahead of time...
ECU: P28
Re: 41 Primary oxygen sensor heater [easy question]
Yeah sounds good having a buddy help me out anyways to save me a headache hes got lots of tools and good cheap labor.
How do i measure the plug i know its a four prong? but what prongs? also, my voltage meter only has only one skewer if you will other is a round metal element.
Bump, anyone have a wiring schematic for the whole O2 sensor circuit. Also my OBD1 D16z6 with I'm assuming the original cx harness only needs a primary O2 sensor because the one after the cat is not hooked up...
For one, your looking at wrong o2 sensor... There is an upstream and a downstream o2... The downstream is the "heated" o2 after the cat... If your upstream was bad you would know it... your car would run like poo and your afr's would be all over the place... However, the rear o2 is pretty much useless and is for emission reasons only...
^An OBD1 D16Z6 only has one O2 sensor (primary).
The Yel/Blk wire in the wire harness connector provides voltage for the heater element.
Here's how to measure the resistance:
Alright cool will try to test the ohms on it tomorrow at some point. But that is what i thought that there was only one O2 sensor and not two. Well i will test the O2 Sensor see if its any good pretty sure its going to be crap. I thought these things were cheap but i guess i was looking at the wrong price cause auto zone said 60 and i thought i read 16 some were =/
Well got excited and tried to test the ohms on the sensor but was getting eaten alive by mosquito's so i gave up.
- need a garage =/
- need a garage =/
Sorry to tripple post but on my O2 sensor i have now their is 2 black wires and 1 white and 1 green.
Was this
referring to the wiring that goes to the ECU?
Was this
Also is there a way i can test the cables that go to the ECU to make sure they are wired properly with my tester?
ForceFed Motorsports
12-27-2013 08:18 PM
D21X
04-07-2005 01:24 PM
