4 wire o2 hook up
4 wire o2 hook up
hello i hard wired in a o2 sensor and now i have a code for o2 sensor a. is it possible to hook up the 2 black wires backwerds?thanks
Re: 4 wire o2 hook up (vw eater)
What happens if you reverse them?
IF one way is correct, the other way will not blow anything up. So just try reversing them.
Re: (orb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orb »</TD></TR><TR><TD CLASS="quote">The car will stall out shortly after starting if the blacks are backwards.</TD></TR></TABLE>
Huh???
It makes no difference, as there is no polarity to the heaters, it is only important to match the colors of the heater wires.
Huh???
Re: (turbob16b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbob16b »</TD></TR><TR><TD CLASS="quote">the black wires can go either way it makes no difference.</TD></TR></TABLE>
ok thats what i thoght and proved today.the 4 wire has a blue wire insted of the green, that dosent matter does it?
Re: (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">Well, what do the directions for the particular O2 sensor indicate that it is?</TD></TR></TABLE>
the smog tech. at work said it was the same ****
Re: (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 »</TD></TR><TR><TD CLASS="quote">Well, if you want to see what each wire correspond to:
http://www.sparkplugs.com/glos...D=328</TD></TR></TABLE>
thats a cool web site and i bookmarked it but i have a walker 02 sensor
Re: (tech8)
i have a very important question(sorry for jacking)
does any one know how to wire in a 02 sensor staright from the ecu.
i have a 96 y7 harness in a p72 ecu with a gsr swap and need to wire in my primary o2 sensor.
all i need are the pinout locations
Re: (HondaPartsHero)
this is the sensor iam using, this sensor should be no problem correct?do u have the wiring chart for it by chance?i hooked up the wires the way they are supose to i think...just put the blue where the green is supose to be? thanks
Re: (tech8)
Huh???
It makes no difference, as there is no polarity to the heaters, it is only important to match the colors of the heater wires.</TD></TR></TABLE>
I could be wrong, but I remember reading that. I'll see if I can find the article/how-to. If you don't mind, could you explain further why that's not the case?
Huh???
Re: (orb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orb »</TD></TR><TR><TD CLASS="quote">If you don't mind, could you explain further why that's not the case? </TD></TR></TABLE>
Why you should be able to reverse the heater leads? For simplicity, picture a lightbulb filament inside the O2 sensor casing. That's what heats it up. It's like a piece of wire...and a piece of wire doesn't have polarity.
Re: (EE_Chris)
so i have it wired like this, is this correct?iam getting ''o2 sensor a code''
i got my obd0-obd1 conversion from this web site http://www.xenocron.com/produc...rness
http://www.xenocron.com/install/OBD0-OBD1.htm
and i have this o2 sensor(walker type b)
-----02 sensor----- ----0bd0-obd1-----
black-heater brown-o2heater control
black-heater yellow-o2 12v switch
white-sensor ground perple-02 ground
blue-signal to computer grey-o2 signal
Re: (vw eater)
Can you take a pic of your wiring job? Honda ECU's are picky when it comes to O2 sensors. They aren't all created equal despite the "OEM Spec" label that a lot of aftermarket O2 sensors carry.
