4 point harness qwestions....
OK... this is the set up i got....
the car...
Where i was told to mount...
ok i was told to mount the long straps the the botom where the seat bolts to the floor.... the pass side strap the where my seat clip is... and nothign about the the driver side one... and it all need to wrap around a c piller bar.... (o ya where can i get a good one if that is how i need to do it... dont need cheep need strong...).....
the car...
You do not want the harness to mount straight behind the seat. apon a accident it could cause spine compression..
Do it the right way and get a harness bar.
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">C pillar a hollow tube that really isnt worth getting..
Harness bar.. Certified for use with a harness and much stronger</TD></TR></TABLE>
Darth ModerVader
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Are you gonna make me post what I posted again?
Get a rollbar or a cage.</TD></TR></TABLE>
He doesn't seem to be interested in actual safety, just in getting those "racing" harnesses installed ASAP.
Re: (tial-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tial-eg »</TD></TR><TR><TD CLASS="quote">that is not it... i just have know clue about this stuff... what is a role bar... and or where can i get a cage... </TD></TR></TABLE>
WOW... dont put your harness in jsut yet.. looks like your just doing it cause ITS COOL.. there is actually a Vital Function to all of these safety items..
Please do not install them. Stop your self right now. you need to do alot of research on these products.
Autopower makes a nice Roll bar/cage setup.. they have a 4 point and a 6 point with bolt in applications which also could be welded to the chassis. Not sure if they are NHRA Certified so that you can run 11.49's or faster.
There is a big list of rules for everything that you want to do. i suggest you start researching
be professional
Re: 4 point harness qwestions.... (tial-eg)
First off, don't use a 4-point harness unless you like submarining under the lap belts and squashing your intestines. 5-point, 6-point or 7-point harnesses are acceptable, but do not wrap the sub strap(s) directly around the front of your stock seat, because you'll still submarine under them. Use a properly-installed FIA 8855-1999 certified seat with a slot in the bottom for the sub strap.
ok i was told to mount the long straps the the botom where the seat bolts to the floor....</TD></TR></TABLE>
Never route shoulder straps directly to the front seat mounts unless you want your spine to be compressed in a collision. They are to be at no more than a 45-degree angle to the perpendicular to your spine - the shallower the angle, the better. Also, if you drill holes through the floor pan to secure the belt ends, make sure you use large backing plates (no, a simple small washer is not enough) to disperse the load and keep them from pulling through.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">and it all need to wrap around a c piller bar.... (o ya where can i get a good one if that is how i need to do it... dont need cheep need strong...)..... </TD></TR></TABLE>
Never wrap shoulder straps around a C-pillar brace or a strut tower brace unless you want a face full of windshield in a collision. ALWAYS mount shoulder straps to a harness bar that is properly secured to your roll bar or roll cage.
Basically, if you don't have a(n SFI padded) roll bar with a proper harness bar, a(n SFI-rated) 5-point (or more) harness, and a(n FIA-certified) seat with a slot for the sub belt, then I recommend that you stick with the stock belts. Safety equipment is designed to work together in a system - any missing piece will compromise your safety and could possibly render the system less safe that the stock setup in some situations.
Re: 4 point harness qwestions.... (DohcSide)
do any of you know a good starting point to start me research.... i have no problum spending money... and the car is being build for auto cross.....
and wow thx... this is why i love honda-tech... so many people with alot of knolage...
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tial-eg »</TD></TR><TR><TD CLASS="quote">and the car is being build for auto cross..... </TD></TR></TABLE>
You should have said that in the first place That harness will be okay for autocross runs. Just don't use it on the street . . .
Mount the shoulder straps to the rear seat belt mounting points on the floor.
Again, I stress, please don't use it on the street or the track, for your own safety. Autocross only.
b18LS
10
11-13-2007 09:05 AM
Gant
34
07-20-2006 09:32 AM
Kilburn
04-17-2005 05:09 PM
6ghatch
01-26-2003 11:29 AM
