4 door integra brakes swap?
I've been searching the site for days, and all I can come up with is:
'94-'01 integra rear brakes will bolt up to an eg. No problem.
What I CAN'T find is whether or not the 4 door integra rear brakes will bolt up. I assume they will, but I don't want to start tearing apart a good car for nothing.
So, plain and simple:
Will "4-door" integra rear discs bolt up to an ej1 ('93-'95 civic coupe)
I have a 4 door GSR, and I'd kill to have the brakes and rear sway bar on my civic.
Re: 4 door integra brakes swap?
The answer to your question is yes. The db8 rears will bolt up to your ej, but you gonna need a 40/40 portion valve or the rears to work. Oh and the fronts will bolt up too if you wanted to convert the front brakes, but then your gonna have to change the master cylinder too.
I third that ^^^
Those teggy suspension parts will fit on your EG or EJ1 . . . You better add the teggy e-brake cables to the list of parts as well.
Nice upgrade and GL!
So all I would need for the front and rear db8 disc brakes is the 40/40 prop valve, master cylinder, and ebrake cables? What about an integra brake booster, do I need that?
I'm not Rick!
the brake boost and mc should always go together. becuase the rod in the mc is matched with the spring inside the brake booster. use that too. thats what i did.
front and rear gsr brakes
gsr MC and brake boost and MC
40/40 prop valve. very nice brakes
Eg6_rAcEr
01-17-2006 04:50 PM
Devine
09-01-2003 10:22 AM
