4-2-1 or 4-1 header?????? eg6 b16a
hi i have a civic eg6 b16a sir2, i wondered what is the best header to go for, is it a 4-2-1 or a 4-1, im kinda new to this so your help would be apprieciated....also is it best to go for a real expensive brand or cheaper etc
cheers josh
cheers josh
Re: 4-2-1 or 4-1 header?????? eg6 b16a (deckster333)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir222 »</TD></TR><TR><TD CLASS="quote">hi i have a civic eg6 b16a sir2, i wondered what is the best header to go for, is it a 4-2-1 or a 4-1, im kinda new to this so your help would be apprieciated....also is it best to go for a real expensive brand or cheaper etc
cheers josh </TD></TR></TABLE>
I would look to pay at least 250+ for a good header and 500+ for a really good one. You typically get what you pay for so if you go cheap you get cracks and cheap all around. If I recall 4-1 is the better of the 2 but it takes up more room under the car so if you are lowered you will scrape even more than normal.
Re: 4-2-1 or 4-1 header?????? eg6 b16a (ralphie14)
depends if you want midrange or high RPM power to decide between 4-2-1 and 4-1, go for the more expensive brand your gonna end up paying for two cheapass ones when they crack, just do it right the first time
ok thanks guys, yes it definately takes up more room under the car... so as im jus drivin the streets, would it be best goin for the 4-2-1 or the 4-1, what does each one do for power gains? (i.e lower rpm or higher rpm)
cheers
cheers
Re: 4-2-1 or 4-1 header?????? eg6 b16a (sir222)
get a 4-1. b16's make most of their power top end and they are very peaky motors. and 4-2-1 are more for midrange-low end power. i gree with the guys about doing it right the first time, but if you want cheap but ok quality, go for the megan racing 4-1 as i have it on my car for about 2 years now with no problems.
Re: 4-2-1 or 4-1 header?????? eg6 b16a (sheBangZ)
4-1 w/2.5" collector felt pretty mean on my brothers old hatch so thats what i would recommend to you, but as stated, it depends on what you want to get from it.
Re: 4-2-1 or 4-1 header?????? eg6 b16a (GottaLoveHondas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GottaLoveHondas »</TD></TR><TR><TD CLASS="quote">4-1 w/2.5" collector felt pretty mean on my brothers old hatch so thats what i would recommend to you, but as stated, it depends on what you want to get from it.</TD></TR></TABLE>
Thats my car your talking about , i had the 4-1 w/2.5 collector on it/ that along with my jdm lsd w/4.78 final drive pulled pretty damn good. Now i'm gonna run the same header on my new set up, then i'll get my sis's(GottaLoveHondas) opinion again, soon as i test it out
ok then thanks very much everyone.
to get the megan header, i think its on all usa web-sites. thing is im in the uk and the usa civics are called different things. so if i wanted to order a header am i right in thinking i should get the one that fits the SI and that would fit my sir2 from japan??
thanks
thanks
Re: (sir222)
get one for any b16.. I'm using one for a 99-00 civic si in my eg and it lined right up with my cat, but its an aftermarket cat so its 2.5 inches. if anything bring it to a muffler shop so they can just put a flex pipe there and weld it with the rest of your exhaust. 4-1 2.5 makes the b16 feel realli good in the high rpm.
Re: (b20vtecda9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtecda9 »</TD></TR><TR><TD CLASS="quote">IMO...4 to 1 > 4-2-1 </TD></TR></TABLE>
your an idiot
your an idiot
Re: (allaboutdaz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allaboutdaz »</TD></TR><TR><TD CLASS="quote">any dyno sheets?</TD></TR></TABLE>
it has nothing to do with dyno sheets, it's more to do with were you need the power.. down low or up top...
also, to do with clearance on lowered cars
Re: (G2 Speed)
its as much the design of the header, tube diameter, primary& secondary length, collector etc as it does on it being 4-1 or 4-2-1.
there was a thread a while back where smsp posted graphs of 2 headers he built, one 4-1 and one 4-2-1. because of how they were designed and built the 4-1 had more midrange than the 4-2-1 and was weaker on the top end.
that being said, IN GENERAL, with off the shelf headers, 4-1 will make more top end and 4-2-1 will make more midrange.
okay thanks. yor all a gr8 help thanks
one other thing i wanted to know was what the best sounding, value exausts are out there for my car, i wanted an angled exit if possible as these look wicked. drift style!
cheers guys
cheers guys
Re: (sir222)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir222 »</TD></TR><TR><TD CLASS="quote">okay thanks. yor all a gr8 help thanks
cheers guys</TD></TR></TABLE>
bhaahahhahahahahahahhahahahahaha
The sound has alot to do with engine, and "head gasket back"
Some people like raspy.. some like a deep tone..
but I'm sure you will like raspy, with the wicked drift style
Drift style? Has "that" franchise claimed another one?
Only angled one I know of is the King of All Cannons, the N1
Just get something like a Apex'i WS2. You'll thank me later.
Re: (black_EM1)
get a type-r or GSR bottom end and keep the stock exhaust manifold, you'll cee way better gains for the price of an expencive exhaust manifold. combine the two things for even better gains.
crazyguy
09-13-2007 04:35 PM
