3mm spacer enough for miata pana style rims?
I already searched and i didnt get a certain answer. Are 3mm wheel spacers enough to clear 96-98 civic ex front calipers? dont want to shave em. Btw the panasport lookin ones. i just need a definite answer then this can be left to sink.
Re: 3mm spacer enough for miata pana style rims? (sohcSUCKS)
emerika had a set on his hatch and he was running intergra rotors, so i dont think there will be a problem with your ex brakes. the problem is that the center hub needs to be bored out to fit on the civic, like stated above. search around in the archives. this was a pretty popular topic about a year ago. good luck
im sorry i forgot to say that i already have them bored they fit fine in the rear but the fronts dont. i put them on and then spun them and they are in fact rubbing the hanger on the caliper. These are the panasport looling ones, they might be different than the hx look a likes. I feel safer with a 3mm spacer than shaving the caliper, but dont want extended wheel studs so i want the smallest spacer possible unless shaving the caliper is perfectly safe.
Re: (sohcSUCKS)
bump. Are hubcentric spacers a must? most i can find are not and have center bore of 75mm and civic is 56.1mm. Searched already and didnt come up with any answers
are these good enough? http://www.jcwhitney.com/autop...03360
Modified by sohcSUCKS at 9:44 PM 10/8/2004
1 Post
3mm or 1/4" should do it just fine Either that or file away a little of the center bore of the wheel... not compfortable with that?, go to a machine shop
Solbros Owns Me
Re: 3mm spacer enough for miata pana style rims? (93CivicSI)
I had 5mm spacers on the front and 3mm on the rears with plenty of clearance.
Only reason I ran the spacers, is to clear the center hub of the wheel away from the hub on my car. This way, I didn't have to bore the hub or anything.
Re: 3mm spacer enough for miata pana style rims? (Emerika)
The rims are already bored out by machine shop as stated in my second post. Im asking if the center bore of the spacers matter as long as they are 56.1mm or bigger and if hub centric spacers are a must. These http://www.jcwhitney.com/autop...03360 will be fine right?
Kyles ej1
44
03-21-2005 09:47 PM
MyWhiteCivic
01-20-2003 06:19 PM
fixhondas
12
09-10-2001 01:55 PM
