3-piece wheel, bolt/stud removal?
Old 01-30-2006, 11:34 AM
phan's Avatar
Default 3-piece wheel, bolt/stud removal?
i recently picked up some work rs-beta and i'm looking to remove the studs/bolts so i can re-polish the lip and powdercoat the center easier. the studs/bolts have like a star-shaped head and i'm not exactly sure what tool/socket i need to remove them. can anyone lead me in the right direction?
thanks
Old 01-30-2006, 11:47 AM
EKtypeRhaTcH's Avatar
they are TORX screws and hardware store carries the tool for it. just gotta know the size.
phan's Avatar
Default Re: (EKtypeRhaTcH)
ah, good ****. so home depot or sears would be fine, right? i just needed a name, and TORX is perfect. thanks a lot.
Old 01-30-2006, 11:48 AM
AutoXer's Avatar
Default Re: 3-piece wheel, bolt/stud removal? (phan)
It's a torx bit, but I have to highly recommend against taking them apart. There is a special process 3 peice wheels go through to make sure the wheel is put together true and with the proper torque.
Old 01-30-2006, 11:54 AM
phan's Avatar
Default Re: 3-piece wheel, bolt/stud removal? (AutoXer)
really? after seeing irresistible nay's blitz 01's, i really wanted to re-do the wheels myself.
Old 01-30-2006, 11:57 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phan &raquo;</TD></TR><TR><TD CLASS="quote">really? after seeing irresistible nay's blitz 01's, i really wanted to re-do the wheels myself.</TD></TR></TABLE>
Yeah, you can't just go around tightening them up around the perimeter, or even crossways like your lugnuts. I don't know the specifics of how it's done, but I know only professionals should take apart 3pc wheels.
You should contact a wheel repair shop, they'll be able to give you a better idea of what's involved, and may even be able to do it cheaply.
Old 01-30-2006, 12:19 PM
phan's Avatar
yea, i understand what you're saying completely, i thought the same thing when you said it...with so many studs/bolts, i'm sure you can't just tighten them in any random order or even crossways like lug nuts. i guess i'll do some more looking into it, thanks.
Old 01-30-2006, 12:24 PM
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldn't be surprised if at the factory a machine does all the screws similtaniously and with a press.
Old 01-30-2006, 02:44 PM
AutoXer's Avatar
Default Re: 3-piece wheel, bolt/stud removal? (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldn't be surprised if at the factory a machine does all the screws similtaniously and with a press.</TD></TR></TABLE>
I'm pretty sure that's how they'd do it on the assy line; but I know there is a process for the wheel repair guys go through to get around it somehow.
koukis_n_milk
10-08-2007 08:59 PM
rollercosta123
03-10-2006 08:01 PM
phan
01-30-2006 11:52 AM
glarock
11-25-2004 07:49 AM
Cheivic
07-11-2003 12:54 AM
Quick Reply: 3-piece wheel, bolt/stud removal?
