22mm Integra Type R swaybar, and ASR Reinforcement Kit for EG6?
Old 03-06-2007, 11:36 AM
kos99ngel's Avatar
Default 22mm Integra Type R swaybar, and ASR Reinforcement Kit for EG6?
I want to go with the kit that JHPUSA offers http://www.jhpusa.com/catalog/...=1842 should I get the subframe only and get myself a bigger swaybar or with the Integra Type R swaybar is enought
Old 03-06-2007, 11:38 AM
HT White Ops
Eran's Avatar
Have you ever driven a car with a 22mm rear swaybar and no front swaybar?
Old 03-06-2007, 11:40 AM
Relic1's Avatar
Enough depends on the intended use, ability of the driver and your front bar.
most people are happy with the 22mm rear bar. and there is no way to be unhappy with the ASR rear subframe.
Old 03-06-2007, 04:11 PM
kos99ngel's Avatar
Witch front bar should I go with? I am getting both front and back.
Old 03-07-2007, 07:46 AM
Relic1's Avatar
a 22mm from a 92-95 EX or a 24mm from a DC2 works well with the 22mm rear.
It depends on how you want the car balanced.
If you're not a track person (track not strip) and you're doing this to keep the car level during cornering on the street, go with the 24mm front.
Old 03-07-2007, 11:36 AM
kos99ngel's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">a 22mm from a 92-95 EX or a 24mm from a DC2 works well with the 22mm rear.
If you're not a track person (track not strip) and you're doing this to keep the car level during cornering on the street, go with the 24mm front.</TD></TR></TABLE>
where would i be able to find the 24mm from dc2? is they're a site that sales the whole setup. front and back
Modified by kos99ngel at 12:47 PM 3/7/2007
Old 03-07-2007, 11:53 AM
Stoich EG2's Avatar
Default Re: (kos99ngel)
what do you use the car for?
Old 03-07-2007, 12:11 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kos99ngel &raquo;</TD></TR><TR><TD CLASS="quote">where would i be able to find the 24mm from dc2? is they're a site that sales the whole setup. front and back </TD></TR></TABLE>
ebay, for sale forum on here, junk yards, etc
also, you will need lower control arms so you can use sway bars.
The ones from an 92-95 EX/SI & DC2 work fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich EG2 &raquo;</TD></TR><TR><TD CLASS="quote">what do you use the car for?</TD></TR></TABLE>
this matters a lot too.
based on your reply above I'd guess street use.
Old 03-07-2007, 12:13 PM
Stoich EG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">also, you will need lower control arms so you can use sway bars.
The ones from an 92-95 EX/SI & DC2 work fine.</TD></TR></TABLE>
i dont think 92-95 ex/si's had rear sway nor had the holes in the LCA for them
Old 03-07-2007, 12:37 PM
Milano Sol's Avatar
you can also use the Front LCA and Sway from a 93-97 del Sol S, Si or VTEC.....last i remember they all had at least the front and its still an EG chassis so it bolts up (what we used on my dads EG Hatch)
Old 03-07-2007, 12:46 PM
kos99ngel's Avatar
based on your reply above I'd guess street use.</TD></TR></TABLE>
I am going to use the car for street use. But yet still I want to get good handling in my car. I am going to be getting aftermarket control arms like omni power or what other brands are good for control arms.
Old 03-07-2007, 12:48 PM
kos99ngel's Avatar
Default Re: (Milano Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milano Sol &raquo;</TD></TR><TR><TD CLASS="quote">you can also use the Front LCA and Sway from a 93-97 del Sol S, Si or VTEC.....last i remember they all had at least the front and its still an EG chassis so it bolts up (what we used on my dads EG Hatch)
i am also going to get aftermarket control arms. witch ones should I go with
Old 03-07-2007, 12:55 PM
HT White Ops
Eran's Avatar
Get BLOX. The new Omni's have urethane bushings, and that's not super great.
Old 03-07-2007, 01:03 PM
kos99ngel's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Get BLOX. The new Omni's have urethane bushings, and that's not super great.</TD></TR></TABLE>
what about skunk2
Old 03-07-2007, 01:04 PM
HT White Ops
Eran's Avatar
what about skunk2</TD></TR></TABLE>
Skunk2 is overpriced. You can get BLOX lca's for about $100 shipped.
Old 03-07-2007, 01:08 PM
kos99ngel's Avatar
Default Re: (Eran)
Skunk2 is overpriced. You can get BLOX lca's for about $100 shipped.</TD></TR></TABLE>
but aren't the skunk2 will i get the same from blox and skunk2
Old 03-07-2007, 01:10 PM
HT White Ops
Eran's Avatar
but aren't the skunk2 will i get the same from blox and skunk2</TD></TR></TABLE>
They'll be the same quality. Feel free to pay $250 for LCA's though, no skin off my nuts.
Old 03-07-2007, 01:34 PM
kos99ngel's Avatar
Default Re: (Eran)
They'll be the same quality. Feel free to pay $250 for LCA's though, no skin off my nuts.</TD></TR></TABLE>
hey what about the camber kit witch one should i go for? I am getting front and back camber kit...omni, skunk2, blox?
Old 03-07-2007, 01:54 PM
Malakai's Avatar
Look here for sway bar/part swap info:
http://www.jdmcivic.com/forums...68355
Old 04-16-2007, 06:53 PM
kos99ngel's Avatar
Default Re: (Eran)
Okay I finally got the ASR sub frame kit along with the BLOX lower control arms and I am going to get the 23mm rear swaybar but I am not sure to get the original endlinks that come with the rear sway bar what about the BLOX adjustable end links the BLOX adjustable end links are $39.99 and the original end links are $80 more.
For my front swaybar I am going with the Blox lower control arms and the 25mm or the 24mm front swaybar
Old 04-17-2007, 07:31 PM
kos99ngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kos99ngel &raquo;</TD></TR><TR><TD CLASS="quote">Okay I finally got the ASR sub frame kit along with the BLOX lower control arms and I am going to get the 23mm rear swaybar but I am not sure to get the original endlinks that come with the rear sway bar what about the BLOX adjustable end links the BLOX adjustable end links are $39.99 and the original end links are $80 more.
still need ur help
Old 04-17-2007, 07:40 PM
eklum's Avatar
i wasnt aware blox made front lcas? and the endlinks for front sways are totally different to my knowledge somone correct me if im wrong.
i currently run a ctr rear sway and asr brace illumnias / gc and front strut / rear strut , no front sway and i love it i really couldnt want more out of the way my car handles for the most part but from my understanding if you wanna counter the oversteer a bigger front sway will help out a bit.
Old 04-17-2007, 08:59 PM
simontseng9's Avatar
Default Re: 22mm Integra Type R swaybar, and ASR Reinforcement Kit for EG6? (kos99ngel)
You can also grab the front sway bar out of the Civic SiR's. I believe they are 24mm, thicker than stock ITR's. However, you'd probably have swap the whole sub frame.
Old 04-17-2007, 09:20 PM
bmoua's Avatar
why waste money on the integra front sway bars...throw on the EM1 26mm bro, i'm planning on doin that to my ej8.
Old 04-17-2007, 10:07 PM
kos99ngel's Avatar
Default Re: (bmoua)
JJSpecTuning that’s really funny u said that about the Omni power that they are better due to the polyurethane bushing they used a couple of post up someone said that the blow are better and the polyurethane bushings aren’t so great. It makes me want to change my control arms to Omni
To I might just go with the Integra sway bar that is 25mm for my front swaybar. What else do I need to install it the front lower control arms swaybar with bushings and the end links I know what else is needed to install it
Quick Reply: 22mm Integra Type R swaybar, and ASR Reinforcement Kit for EG6?
