2001 Gsr Motor swap into my 2000 civic sohc non vtec help please
I need help please, First i would like to apoligize if this topic has appered a million times.
Any information, would be greatly apreciated. I have a 2000 honda civic 4dr. The motor is a sohc non v-tec. It is a Candian Model (Se) If that Makes any diffrence. I have Auto Transmission. The swap i would like to do is this. A motor out of a 2001 gsr with the 5 speed gsr tranny and Axles. The motor comes with the ecu. Any info on this swap would be so helpful. Thanks |
Re: 2001 Gsr Motor swap into my 2000 civic sohc non vtec help please (CanCivic2000)
http://www.hondaswap.com SEARCH
is your warranty done, if not you might void it.
Re: 2001 Gsr Motor swap into my 2000 civic sohc non vtec help please (frostcivic)
My warrenty is done, So theres no isuue there.
Does anybody know how i will get the v-tec to work, do i need a v-tec contoroller? |
Re: 2001 Gsr Motor swap into my 2000 civic sohc non vtec help please (pissedoffsol)
I though that EKs had the same tranny mount no matter if it's auto or manual. I thought it only was for EGs.
Re: 2001 Gsr Motor swap into my 2000 civic sohc non vtec help please (ABK)
you are correct.
the tranny mount location does not need to be cut and re-welded. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frostcivic »</TD></TR><TR><TD CLASS="quote">is your warranty done, if not you might void it.</TD></TR></TABLE>
might? https://honda-tech.com/forums/images...s/emhammer.gif |
Re: 2001 Gsr Motor swap into my 2000 civic sohc non vtec help please (BADEG6)
Thanks for the help so far, I have been reading up on the project. I have found alot of great information even though some of it conflicting. My hope for this form was to find somone who has documented the same swap with pictures. I am still searching for that.
I starting my swap in a couple of weeks and will be documenting the whole thing step by step with pictures. I will post it, if it is posible. |
