2000 SI Timing Belt Replacement , what else should be done?
Re: 2000 SI Timing Belt Replacement , what else should be done? (schlit)
1qt every 3000 miles is pretty damn healthy for a b16.
I would absolutely replace the tensioner and the spring. Everything else is on your list already. Dealer will probably charge you for valve cover gaskets when they do it.
Re: 2000 SI Timing Belt Replacement , what else should be done? (LdyJeRk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LdyJeRk »</TD></TR><TR><TD CLASS="quote">Is it really necessary to replace tensioner?</TD></TR></TABLE>
yes its a big yes.. that is something u def need to change
don't forget to check all your hoses while your in there, they always happen to blow when you least expect it. It is best to go with OEM hoses, belts, and tensioner. I have had problems with aftermarket drive belts making noise and dayco hoses last have as long as OEM. Also check your distributor o-ring if your going on a long trip, they tend to leak with age.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit »</TD></TR><TR><TD CLASS="quote">
The last T-belt I changed was on an accord which didnt have a tensioner, so I am unfamiliar with them. What goes bad and what happens when they go bad?</TD></TR></TABLE>
I've done several accords from 88's to 99's and they ALL had tensioners.
when it goes bad it skips teeth and timing goes completely out of wack or it could lock up and tear your timing belt to shreds
Re: 2000 SI Timing Belt Replacement , what else should be done? (EGchicSOHC)
does the d16z6 have a tensioner? bc as far as i know i havent ever had to change it and i got it at 95,00 miles and im know on 155,00 miles???
Re: 2000 SI Timing Belt Replacement , what else should be done? (sohctodohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohctodohc »</TD></TR><TR><TD CLASS="quote">does the d16z6 have a tensioner? bc as far as i know i havent ever had to change it and i got it at 95,00 miles and im know on 155,00 miles???</TD></TR></TABLE>
Yes, it has one.
Yes, it has one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGchicSOHC »</TD></TR><TR><TD CLASS="quote">when it goes bad it skips teeth and timing goes completely out of wack or it could lock up and tear your timing belt to shreds</TD></TR></TABLE>
What are you talking about? ALL Honda motors are interference engines. Skipping a tooth MIGHT be "ok" on some of the lower compression econo versions, but you skip a tooth on some of these and you will kiss valves.
Not gonna argue with you.....If it had one, nobody made a big enough deal about it to warrant spending money to change it. I've never had access to a shop when its come time to change my T-belt, so it's one of the things I've never done myself so forgive my ignorance sir.
Honda didnt include the tensioner in the typical T-belt replacement schedule. You seem pretty familiar with the part, do I really run the risk of skipping teeth?</TD></TR></TABLE>
Its not one of those things that is just assumed "should be replaced no matter what". If it failed, would it cause a problem? Sure. Would it skip teeth? I highly doubt it. When you do the timing belt, simply remove the tensioner, give it a roll. Check the bearing to see if its binding and also check for looseness (wobble). If its bad, replace. If not, life goes on. I've NEVER replaced it on any of my personal cars and I have yet to have issues with one failing. The will make PLENTY of noise LONG before they sieze completely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LdyJeRk »</TD></TR><TR><TD CLASS="quote">how long tensioner usually last b4 it gets bad?</TD></TR></TABLE>
Did you read my response? Thats like asking "about how many miles does an engine usually last before it fails?
MonkeyPuzzle
12-30-2013 04:04 PM
LicenzedToThrill
11-14-2005 03:39 PM
99_dc2
10-01-2005 12:43 AM
Intercooler
23
11-21-2004 07:39 PM
2000CivicSiLasVegas
05-17-2004 09:34 PM
