2000 SI cluster in 98 EX RPM and MPH wont work!! (HELP)
so here is the problem.
I have a 98 ex with a B16 off a 2001 SI (motor runs fine)
But when I tred switchin to the SI cluster the RPM and the MPH wont work...
Can anyone help me with this?
I though they were supposed to be direct swap?
If anyone could help me it would be greatly appreciated!
Re: 2000 SI cluster in 98 EX RPM and MPH wont work!! (AnDy327)
they are plug and play.. does everything else work on the gauge cluster? and did your previous cluster work fine?
Re: 2000 SI cluster in 98 EX RPM and MPH wont work!! (geneeunit)
yes everything works fine on the other one.. And im sure its not the cluster because I put it in my buddy'z SI and it work'd fine...
I changed the wire harness that goes behind the dash and into the ECU (trying to make an SI replica)
Is there a way I can run a wire from were ever it gets its signal to the cluster?
so your previous cluster works with your new harness, while the new cluster does not? or do you not have another cluster to test?
I dont have another cluster to test this harness with... But before I pulled it out of the car both the cluster and the harness along with ECU and Engine worked fine...
Its now that I put it in my EK that they dont want to work..
I got the complete swap from an SI that was rear ended so I just pulled the whole front end off
ok, first thing i would do.. is just double check all your connections. make sure you plugged everything in properlly and check the harness for damage to the wires.
and does everything else on the cluster work? and how about the rest of your car? climate control panel, car runs?
All clips are on (tripple checked)
Temp works fine
Gas works fine
All the climate controls are working fine...
Its just the RPM and the MPH....
I looked up wire schematics and all my wires behind the cluster are to were they need to be... I ran a wire to my dizzy from the cluster so now my RPM's are working... Just not my MPH
Temp works fine
Gas works fine
EDIT:: VSS sensor?
since you just swapped the motor right? is it plugged in?
Modified by geneeunit at 11:57 PM 6/22/2008
yeah, it's on the trans. "Vehicle Speed Sensor" im not positive where its at on B-series engines, but on a D its located right under the intake.. here.
(Picture Stolen Off Google. )
LOL. Sorry I woulda know what you were talkin about if you would have spelt it out.. Bu yes I also checked that and I even pulled it out to check if it was broken. Everything looks good...
I tapped a wire from the RPM over to the MPH on cluster. And when I reved it a lil It moved so im sure its Wiring...
I do have one. But its because of my O2 sensor...
Im using a P2T..... Would this make a difference?
i dont think it could be your ECU.. most likely its the VSS sensor though. do you have one from your d-series still? you can use that on the B-series, you just have to swap some parts out.
http://hondaswap.com/general-t...28865/
but i really have no idea what else it could be besides that, or faulty wiring.
z-28john
10-23-2014 01:57 AM
1999jdm
11
04-17-2013 04:22 AM
JSPECEX
03-23-2003 07:53 PM
