2000 Honda Civic EX ATF Change Help
No Sales Forums
I have 2000 Honda Civic EX with an automatic transmission. It has 165,000 miles on it. I wanted to get the transmission fluid changed but I'm very confused as to what brand I should use. Should I use Genuine Honda transmission fluid (ATF DW-1)? Or should I use Red Line D4 ATF? Or should I use Red Line D6 ATF? What's the difference between the D4 and the D6? Which one should I use? Is there something better I should use instead? Any help would be much appreciated. Thanks in advance!
No Sales Forums
Re: 2000 Honda Civic EX ATF Change Help
My Honda Technician told me how to do a home flush. Need a buddy to help.
You drain and fill the transmssion first, on mine it's between 3 and 3.5 liters. Then you disconnect the return line from the top of the transmission, have your buddy start the car and shut it off after it pumps out 1 liter, add 1 liter to the transmission, start the car and drain 1 liter and turn the car back off, then add another liter of fluid.
He said for my old D series tranny it would take about 8.5 liters to do a full DIY flush.
Once done, reattach the return tube to the transmision.
You should be able to do the same thing with yours.
No Sales Forums
sharpescalade
06-02-2007 07:37 AM
