2000 ex weired noise question, only when clutch is out, no noise when clutch is pressed in?
Old 08-06-2006, 05:24 PM
B16CivicEX's Avatar
Default 2000 ex weired noise question, only when clutch is out, no noise when clutch is pressed in?
hey guys, i have a 2000 ex its makeing a raddling noise when pulled thru 1st and 2nd gear, below 3k RPM's when i push the clutch in the noise goes away. i can idle the car and with the clutch in no raddle, with it out, and the car in nutral it will raddle, sounds the the tranny somwhere, hard to pin point.
Old 08-06-2006, 05:28 PM
B16CivicEX's Avatar
Note: also the clutch is stock, and still grabs hard, still will chip 2nd, and not slip if this helps?
Old 08-06-2006, 05:30 PM
Rock Meathammer's Avatar
Default Re: (B16CivicEX)
Flywheel is possibly cracked or loose
Old 08-06-2006, 05:33 PM
It could also be a throwout bearing problem, but that is generally a whining type noise.
Old 08-06-2006, 05:42 PM
B16CivicEX's Avatar
its more of a raddling type noise.. i guess off to the dealer it goes. sucks.
Jhonny Ricer's Avatar
Default Re: (B20 EJ6)
Could it maybe even be a heat sheild vibrating? check them !
Old 08-06-2006, 05:44 PM
B16CivicEX's Avatar
but would a heat sheaild only raddle with the clutch out, and go away when pressed in??
Also- can i check the flywheel thru the inspection cover, and not have to pull the tranny
Old 08-06-2006, 05:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CivicEX &raquo;</TD></TR><TR><TD CLASS="quote">
Also- can i check the flywheel thru the inspection cover, and not have to pull the tranny</TD></TR></TABLE>
Not a thorough inspection to find cracks. You can tell if it's loose though. I highly doubt it's loose if it's never been apart from the block.
Old 08-06-2006, 05:58 PM
Too bad you're that far away, I would've checked it out for you at my shop. It may be a few hours for the drive, but you will atleast get a true and honest answer.
Old 08-06-2006, 06:15 PM
Well my guess would be the heat sheilds due to the exhaust moving when the engine is actually "running" per say. But when you have the clutch in its not causing your exhaust to rattle due to the very low airflow through your pipes.. Id say before going and paying just take a quick look at the sheilds see if they are loose if so tighten them.. Than see if the rattling persists if it does have someone take a look at it for ya
Old 08-06-2006, 06:28 PM
CooBlueDAB's Avatar
Default Re: (Jhonny Ricer)
not throwout bearing, it would make noise with clutch in, however sounds like my current problem in my 99 si... mainshaft bearings etc...
Old 08-06-2006, 06:31 PM
axtran's Avatar
Input Shaft Bearing is usually the culprit. Tranny noise is usually 3 things with Hondas - Throwout Bearing, Input Shaft Bearing, or F'ed Up Tranny. LoL
Old 08-07-2006, 02:48 AM
B16CivicEX's Avatar
how bad of a job is the input shaft bearing? and is it safe to drive like this for a while?
Old 08-07-2006, 05:07 AM
Ek Forever y0!
Libertariat's Avatar
I always confuse input shaft and throwout. I think it's throwout when the clutch is not engaged... but i may be wrong.
Anyways, local shops around her wanted $600+ to fix it. Yes you can drive on it, but you can also pick up a decent ex tranny for $300 and replace it with a helms. Presto, transmission fixed and betterer.
eg_b18c
Transmission & Drivetrain
17
10-31-2018 07:24 PM
Drag_On
02-26-2006 05:33 AM
Gen5lude
10-19-2004 09:48 PM
garados
02-03-2003 11:08 AM
Buckshot
11-06-2002 05:29 PM
Quick Reply: 2000 ex weired noise question, only when clutch is out, no noise when clutch is pressed in?
