2000 Civic SI rear swaybar endlinks
I am wondering if anybody knows of a company that makes the rear swaybar endlinks for the 96-2000 Civics. I do not like the factory pieces because they are mostly plastic and cost a fortune. If there is another company that makes replacements let me know. I have searched the web and cant find anything. Thanks
Re: 2000 Civic SI rear swaybar endlinks (CRITTERMATT)
plastic? I dont think so.
My 99-00 rear sway bar and endlinks are all metal, with poly at the LCA, and honda juice boots. No plastic here.
Re: 2000 Civic SI rear swaybar endlinks (4g4me)
apparently you have never taken your apart then because yes they are plastic. i took apart a junked one i got on an oem swaybar and the socket that the ball sits in is plastic. i know for a fact
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT »</TD></TR><TR><TD CLASS="quote">apparently you have never taken your apart then because yes they are plastic. i took apart a junked one i got on an oem swaybar and the socket that the ball sits in is plastic. i know for a fact</TD></TR></TABLE>
The enlinks on my SI sway bar are not plastic. I have a hard time believing that a piece of plastic can prevent a 2450lb car's rear end from rolling.
Re: 2000 Civic SI rear swaybar endlinks (kommon_sense)
take apart then. there is a long metal bar that has a ball joint around it. the socket that surrounds the ball is plastic. if you llok at the end caps you will notice four gray circles of plastic this is what surrounds the ball joint. believe me it is plastic. i have another junked one and if i get a chance i will take it apart and take pictures.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT »</TD></TR><TR><TD CLASS="quote">take apart then. there is a long metal bar that has a ball joint around it. the socket that surrounds the ball is plastic. </TD></TR></TABLE>
Ok... So the endlink is metal. It is the black cap that is plastic.
94rs-turbo
05-31-2007 01:26 PM
