2000 civic si Q's
2000 civic si Q's
ok so i dont know much about b series but what do i have to do to swap the b18c5 in a 2000 civic si? wireing,ecu,mounts, that kind of stuff thanx for your help
Re: 2000 civic si Q's
i have a complete 2000 civic si with everything and i have a complete 2001 itr car with everything so what harness and ecu do i use?
the ITR wire harness and SI harness should be the same... they are both OBD2 DOHC VTEC harnesses so you shouldnt worry about swapping harnesses. I would use the ITR ECU with the ITR motor it will be better preset and wont need to be tuned right away
the ITR will throw down something like 198hp 150tq at the crank...i think (not 100% sure off the top of my head)
ok so i was also thinking of doing a build with the b16 si head since the bottom end is crap is the b20 a goor idea "for the future"?
that my friend is your decision. do you want to stay NA or would you rather play with boost? since you have the ITR motor i would keep it NA, build the head with new springs/retainers and throw a set of stage 2 cams in it.
As for the b20 you have to ask yourself the same questions... what is your overall goal with the car. do you wanna build a b20-v?
true im not sure about the b20 thing i have just heard about it in the past and was wonderin im sure this wont be my last honda i already have 2 many projects as it is so i will prob. hold of on the b20 i might just put it my k24a2rsx but dont know yet i guess im just throwin ideas and tryin 2 get some back well i thank u man alot of other sites wont help me so thanx
SR200
10-23-2006 08:26 PM
CNSK
16
08-27-2004 09:15 AM
