2000 civic running toooo rich
Well, i was able to get my car running (just a weak battery) but my car seems to be running really rich( my air/fuel ratio gauge shows me that) and white or black smoke comes out from the exaust, spark plugs are black, im just clueless already, could my timing be off? when i rev it and the the rev comes down, it sounds like it almost dies out then it idles funny kinda a like a mild cam would sound like. Any suggestions would be helpful, Thanks...
Re: 2000 civic running toooo rich (boostedcivicsir)
well i have
-cold air intake
-headers
-2.25 mandrel bent exaust
-unorthodox racing light weight pulleys
-stage 2 clutch & 8.5 lb flywheel
-New MAP sensor
-New (rear) o2 sensor
-New alternator
-MSD sci box
-OBX racing spark plug wires
-OBX Irridium spark plugs
-cold air intake
-headers
-New MAP sensor
-New alternator
-MSD sci box
Re: 2000 civic running toooo rich (si_motor_spt)
Thanks for da help guys, more would be good to, im not to sure if its timing though cuz it stars right up...
Re: 2000 civic running toooo rich (MatterMatt)
Check your tps sensor to see if it's calibrated properly....do you have any check engine lights?....get them checked if you do.
Re: 2000 civic running toooo rich (1sIck_EM1)
NO CHECK ENGINE LIGHTS OR ANYTHING, but how do you remove the TPS sensor? on mine, theirs 2 screws but theirs nothing to remove it with(no flat head slot or a philip slot either) how do you remove the screws????
DON'T REMOVE IT! Check to make sure the sensor gives the right signal voltage before messing around with the TPS setting. A Helms manual will tell you the right voltage (I think it is around 4.5V, but don't take that as gospel) and which wires to check it from. If the voltage is off, loosen the torx screws a little and adjust the sensor position as necessary (watching the DVOM reading as you move it). Don't go moving it until you are sure your timing and fuel pressure are correct first!
how do i remove the torque screw? the 2 bolts on my sensor are jus flat thats why, do i drill the screw or something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_motor_spt »</TD></TR><TR><TD CLASS="quote">how do i remove the torque screw? the 2 bolts on my sensor are jus flat thats why, do i drill the screw or something</TD></TR></TABLE>
I don't think you can remove the screws on the tps sensor...they're like rivets...the way you can test the calibration was posted before...but before you test out your tps sensor....check the timing...see if your crank and cams are lined up at TDC....your primary o2 sensor can be going bad...since you only changed the after cat one.
