2000 Civic EX - replacing oil rings.
My friend has a 2000 EX (Si in Canada). He's burning alot of oil right now... what could be the possible causes? And... the cost involved (he's not a DIY guy)... so he's willing to take it to a dealership to maintain warranty.. bla bla bla.
Any help would be appreciated.
Edit... I didn't type the subject line! lol -- that was my buddy!
REMOVED what I said about the wrong forum since this is a pretty general topic. Anyhow, burning oil can be a lot of things. How much is he burning for starters? A quart a week? A quart per 100 miles? Typically the issue is either a) valve seals or b) piston rings. Either are fairly expensive, but COULD be done over a weekend w/ some help. Rings involves pulling the pistons rods and head. Valve seals will involve just pulling the head. An easy way to diagnose the problem is a compression test and a leakdown test. Post the results of that and we can discuss further what problems there may be.
Re: 2000 Civic EX - replacing oil rings. (The Setup)
Honda will likely not do an leakdown test. Theyll tell you its normal for the car to burn a quart every 1k, possibly run an oil test with additives added to the oil. theyll make him go back there every 500 miles or so a few times to check on the status or anything to give a run around. Then theyll just say the cars fine without any type of work done.
Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Leakdown test will give you more specific information than just a compression test.</TD></TR></TABLE>
im having bad oil comsumptions too. about 1 quart every 1000 miles. i did a compression test and had 180 all across.
how do i do a leak down test. is there a DIY thread with pictures or good descriptions.
i searched but cant find anything useful
A leakdown test requires an air compressor and a fairly expensive tool. Best to get done at a mechanic if you do not have the equipment immediately available to you. Here's a nice link explaining some things:
http://www.xs11.com/tips/misc/misc3.shtml
rob_nordberg
08-09-2012 08:30 PM
alchemyst6
18
07-21-2011 10:08 AM
