2-step woes EG d16z6
I had an extra N2MB launch-control, WOT shift setup so i decided to wire it up to my stock EG hatch. Well i got everything to work, but when i tapped into the BLACK/YELLOW wire on the distributor, and try depress the clutch to cut ignition timing the car shuts off COMPLETELY, it does not matter if your at 6k rpms at 60mph or at idle any thoughts? the BLACK/YELLOW wire is your main "ignition coil power wire" correct?
