2 Step and 3 Step
Re: 2 Step and 3 Step (Quick Hatch)
Ones higher then the other. Imports dont usually use 3 step unless there really high up there power/low times.
2 step is usually for burn out, 3 step is for launch from what i understand. You could set the 2 step to kill fuel or spark, spark is usually what you want killed.
Re: 2 Step and 3 Step (Luserkid)
Just to clarify for you guys,
2 step= 2 rev limits (one for launch/burnout) and the other is the overall rev limiter.
3 step= 3 rev limits. One for launch, One for burnout and the other is the overall. Most racers using 3 steps use a certain RPM to do a burnout on(for consistent tire temps) and one to launch off. The other is the overall which is self explanitory.
Most quality EMS's and aftermarket ignition sytstem's will use an ignition cut while most of the DIY EMS's use a fuel cut. Both can build boost and both are safe IMO.
Phil
Phil
Re: 2 Step and 3 Step (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">Just to clarify for you guys,
Phil</TD></TR></TABLE>
Thank you very much. I was terribly confused before I saw what you wrote.
hondacummins
Engine Management and Tuning
12
07-20-2014 08:14 PM
DamonBoost
10-28-2001 01:54 AM
