2 questions on eibach sportlines (quick)
for 92-95 hatch
1.) Does the front seem to sit higher than the rear? (integra owners say so)
2.) Do I need a camber kit? (Eibach says its a 1.6' drop)
Thanks in advance
Thanks in advance
Re: 2 questions on eibach sportlines (TEGPOWER44)
What Springs are you using (Integra or civic)?
if you are using Integra yes it will sit higher with your d series motor
camber kit will need if you need one or else you can get by
Re: 2 questions on eibach sportlines (ace1875)
Sportlines will make your fronts lower than your back.. also the drop is not that much to the point where you will need a camber kit.. You can take it to a shop and get them to align it to almost if not spec with those springs on.
I use to have them on my '00 Si and I had them aligned to spec w/o any camber wear on my tires.
I've got sportlines on my hatch, they look pretty level to me. I got a camber kit and so I would suggest getting one also.
I am riding on Sportlines and the front is just a bit lower than the rear. That may be due to B18b swap + Civic rate springs?
Also have a camber kit installed on front suspension.
Re: 2 questions on eibach sportlines (Outrun)
Do you guys think eibach pro kits and kyb agx shocks would be a good combo? I know pro kits lower it a little bit, can I do a little more with the shocks? What are the pros and cons of this? Thanks
Pro Kits are designed for stock dampers, so you should be fine. But if you want the adjustability, the KYBs should work okay. Only con I can see is more money. If that's not an issue, than sure, why not?
madcrossover
10-19-2004 10:05 AM
loki2323
10-02-2002 12:34 PM
