2 questions
2 questions
do u have to take the header off to replace the oil pan gasket?
and
if a rear main seal is leaking oil would it be a substantial ammount?
ive noticed oil saturation around the seam of my oil pan and towarsds the bottom front of the engine. fyi no leaks up top, bibe dry. and also no drops of oil on the ground. thanks.
and
Re: 2 questions
Depends on the car. You didn't say if this is even a Honda let alone year/make/model/trim and any mods.
Rear of the engine is transmission side, you are saying front of the engine. This detail does make a significant difference in the amount of work as well as cost.
You need to clarify which seal you suspect is leaking.
Re: 2 questions
Re: 2 questions
Stock? What engine?
Re: 2 questions
Sounds like dizzy o ring to me.
Re: 2 questions
If you clean the motor and the leak comes back on the bumper side of the oil pan and no where else, your oil pan gasket is leaking.
You won't really know until you clean it up and observe for a bit.
Re: 2 questions
Getting rather technical here but the bumper side of the engine is actually the side of the motor. The front of the motor is the timing belt (drivers) side and the rear of the engine is the transmission (passengers) side. Our motors are mounted sideways with a transaxle. The "sides" of a motor still typically go by the original layout of the rear wheel front engine car where the crank pulley is the front, the transmission is the rear and the sides usually have the manifold(s).
Re: 2 questions
For B and D series motors you usually have to remove the header unless your certain vehicle you can disconnect the rest of the exhaust from the header and be able to drop the oil pan. As for the rear main, sometimes they'll leak badly other times it'll just be seepage.
Re: 2 questions
Anyways, you remove that section if your exhaust is setup like that and you can drop your oil pan with no issues.
Re: 2 questions
thank u. im hoping its not a rear main. ill change the oil pan gasket and see...
Re: 2 questions
Not sure on the b-series but many of the d-series headers are a 2 piece design so you can just disconnect the bottom half of the header that goes into the cat below the car. Usually called the "A" pipe, which I thought was because it's two pipes into one resembling the letter A.
Attachment 393784
Attachment 393784
flyjazz
08-13-2009 10:07 PM
infinkc
07-27-2009 12:02 PM
