2 problems wtf???
Old 04-10-2008, 07:31 PM
foowitdaredek's Avatar
Default 2 problems wtf???
well first problem....
for some odd reason one of my spark plug wires keeps comming loose, could this be a potential hazard?
the other is, sometimes when i have the clutch pressed in i hear this noise. as if there was a little motor running.... like when you wet your windshield with the nozzles you hear that motor. all help will be gladly appreciated.
btw the car is a 1996 civic ex. thanks
EDIT: that noise isnt just when i press the clutch, but when i roll backwards.
Modified by foowitdaredek at 9:42 AM 4/11/2008
Old 04-10-2008, 07:40 PM
Former User's Avatar
Default Re: 2 problems wtf??? (foowitdaredek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foowitdaredek &raquo;</TD></TR><TR><TD CLASS="quote">well first problem....
Does the plug or wire seem damaged? If so, replace.
Old 04-10-2008, 07:42 PM
i checked both of them and they looked fine.... i am gonna replace soon. but i just wanna know if there will be any problems.
Old 04-10-2008, 07:45 PM
Default Re: (foowitdaredek)
I think you risk damaging the distributor coil, igniter, etc.
Old 04-11-2008, 08:12 PM
anyone else?
Old 04-11-2008, 08:22 PM
littleblue's Avatar
Location: On a island w/ only a bridge to leave it, U.S.A
Hmm when you roll backwards, How are you brakes?
Old 04-11-2008, 08:40 PM
Frickr's Avatar
Default Re: 2 problems wtf??? (littleblue)
the clutch could be a throwout baring
Old 04-11-2008, 08:46 PM
Mugen112's Avatar
Sounds like your inner shaft bearing may be going out. Not easily replaced, but can be done. Won't be able to tell where the noise is coming from until you open up the tranny. If you do decide to remove the tranny, try to move the shaft around to feel for any play (this would indicate a bad bearing). As for the spark plug wires I would get new wires anyway. If they're new, they probably have a warantee for stuff going wrong like that. If you do decide to get some new wires, go NGK no matter what. You wont regret it.
JDM_SOHC
04-30-2007 02:24 PM
artraffle
08-19-2005 03:59 AM
dizzyroc88
02-01-2004 07:34 AM
Audio28
11-08-2003 07:22 AM
Projekt20
10-11-2002 10:24 PM
Quick Reply: 2 problems wtf???
