1999 Civic LX - Automatic Transmission shifts hard or won't shift at all
Hi all, I have a Civic LX, 99 with a 4 speed auto tranny. Got the D16Y7 NON-V-Tec motor in it.
Im having a little problem, recently it shifts hard and sometimes it doesnt like to shift at all until i let off the gas a little bit or floor the gas for a little amount of time. It never used to shift hard and used to shift fine at normal RPM.
The car has 106k miles on it and its all stock.
The fluids have always been maintained, oil change at 3-4k miles at a shop.
I checked the tranny fluid and it is fine in color and is to a safe level.
Someone told me to have a tranny flush done, but im afriad because someone else told me that sometimes if you havent had a tranny flush that you can cause more damage to the tranny than if u leave it, i never dont a tranny flush in my car.
What do you guys think?
I drive the car prolly about 120 miles a day.
Re: 1999 Civic LX - Automatic Transmission shifts hard or won't shift at all
Does the CEL work or did you check with a code reader?
If there are no CEL codes, start by draining and refilling the transmission three times, with a short drive in between. Use only Honda or Honda-recommended ATF.
I know the CEL works, cause if went on after i left my gas cap off my car hahaha.
and okay i will try that i just ddnt want the tranny to start slipping
I was looking at some searches and found that flush out some tranny fluid and also replace the Linear shift solenoid also. Here is the article. WHere is this solenoid located and can i do this or should i take it to the shop?
Im getting all of these symptoms, shifting harsly and sticking in first gear sometimes.
TSB Number: 00-012
Date: June 20, 2000
Applies To:
1996-00 Civic - See VEHICLES AFFECTED
1997-99 CR-V - See VEHICLES AFFECTED
Harsh Shifting Automatic Transmission
(Supersedes 00-012, dated April 4, 2000)
SYMPTOM:
The transmission shifts harshly, or it may stay in first gear. The MIL may be on with DTC P0730 or P0715 stored.
PROBABLE CAUSE:
Contamination of the linear solenoid and its associated passages inside the transmission.
VEHICLES AFFECTED:
1996-99 Civic - All with A/T (except HX with CVT)
2000 Civic:
4-door DX, LX - From VIN 1HGEJ6...YL000001 thru 1HGEJ6...YL019847
4-door EX - From VIN 1HGEJ8...YL000001 thru 1HGEJ8...YL020169
4-door EX - From VIN 2HGEJ8...YH500001 thru 2HGEJ8...YH522686
2-door DX - From VIN 1HGEJ6...YL000001 thru 1HGEJ6...YL025993
2-door EX - From VIN 1HGEJ8...YL000001 thru 1HGEJ8...YL026389
3-door CX, DX - From VIN 2HGEJ6...YH100001 thru 2HGEJ6...YH1025571997-99 CR-V - All
CORRECTIVE ACTION:
Flush the transmission with Genuine Honda ATF, then replace the linear solenoid.
PARTS INFORMATION:
Linear Solenoid Assembly/N 28250-P4R-315, H/C 5317219
*Drain Bolt Washer: P/N 90471-PX4-000, H/C 3300936*
In warranty:
The normal warranty applies.
Out of warranty:
Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work.
You know what I would do? If you car falls inside the affected VIN numbers, I'd try it. If it works you saved yourself the cost of another transmission. If it doesn't work, well you rolled the dice and came up snake eyes.
FIY a Linear Solenoid is $142.55.
TSB Number: 00-012
Date: June 20, 2000
Applies To:
SYMPTOM:
PROBABLE CAUSE:
VEHICLES AFFECTED:
2000 Civic:
CORRECTIVE ACTION:
PARTS INFORMATION:
In warranty:
Out of warranty:
