1999 Civic EX burning oil
Ive had my car about 2 years now and within the last year we've changed to a full synthetic motor oil and it seems to be leaking more and more. it leaks out about a quart to a quart and a half every month, yet there are no stains on my driveway or when i out the car in motion. there is a small leak on the valve cover (Z6 vavle cover on a Y8 head). i think that it may be passing through the rings and burning out because the tip of my exhaust is black all over. question being, is there ANYWAY that i can fix it from passing through the rings without replacing the rings themselves?
Re: 1999 Civic EX burning oil
What color smoke is coming from the tail pipe? --->Blue = oil, white = coolant, black = fuel.
I'd start by fixing any oil leaks seen on the engine. Replace the oil pan and valve cover gaskets if necessary, and also check for leaks from the distributor, VTEC solenoid, oil pressure switch, and oil filter.
well 1st of all synthetic oils are more slippery to the touch. if u have a leak stop using synt and use conventional. and use lucas to thicken it makes leaks less when using a thicker oil. and NO u cant fix it without changing the rings how would that work. u cant fix an internal prob without doin it right . its a honda they all will eventually leak just keep it full of oil ull b fine. for now anyways
smoke was the first thing i checked, and there isnt any coming out of the tail pipe while driving. looked over the whole motor yesterday and the valve cover gasket is the only thing that looks to be leaking. so we're in the process of changing that within the week.
gas mileage is aboout 32 MPG the past couple of tanks which is normal for my car. and as a matter of fact i was riding down the interstate the other day in forth at about 6500 RPMs going up hill. Was at 6500 for about 30 seconds when it just died out and the CEL came on. so i geared up to drop the RPMs. well when i got off the exit ramp and took off from the stop light every gear that Vtech engaged it would die off, like it was pulling off. well i turned the car off and let it sit overnight and it runs fine now. i checked the oil after it happened and it was a quart low, so i figured it was just a spike in oil pressure.
ppl make a mistake of listening to helpless info from ppl whom dnt know anything about oils. i was SAE certified salesman for penzoil and u ever hear of a blended synthetic? its conv and syth mixed. and also all petroleum is compatible with itself, the diff between the 2 is the molecular design. conv molecules are all diff sizes and synth all the molecules "man made" are all the same size thats what makes its slippery to the feel. its a total lie and hoaks . look it up! i promise u can go back and forth, if not explain why then
Given that you are burning and/or leaking engine oil, you must daily check the level to avoid running it low. Otherwise, the way you drive your car, it may soon be damaged beyond repair. For what it's worth, I'd stick with the synthetic oil just because in the long run it's better for the engine.
Also, is the leak from the valve cover possibly coming from the VTEC solenoid?
I think you should compression test the cylinders and then repeat the tests after adding a teaspoon of oil to each cylinder. If the compression values rise substantially with addition of oil, then the piston rings are certainly bad.
dude im not flamming you in anyway shape or form. but for ur info go to google and ask if u can switch, it will pull up helpful info for u. ppl at like jiffy lubes and pepboys will telll u u cant switch bc if u go back they lost a sale. i was actually just trying to help ur knowledge but if u dnt want it then i wont help you !
You couldn't be losing that much oil from the valve cover and not see it completely covering the engine bay since it'd have to be spraying out to lose that much
PICS of the spot
my car was running on synthetic when it was in california by the 2 previous owner
im like the 3rd owner running on regular conventional its still running same old honda
own a 94 hatch civic
