1997 Honda Civic EX VTEC Oil Pan ?
Old 12-16-2012, 09:12 AM
LakersFan_73's Avatar
Default 1997 Honda Civic EX VTEC Oil Pan ?
Hi guys,
I recently bought a 1997 Honda Civic EX vtec that needs the oil pan replaced. I read the VTEC uses a different style oil pan than the non-VTEC such as the DX or other base models. Assuming that information is correct, I am having a hard time finding a replacement oil pan with a reasonable cost for my car. What I have found is the base model oil pans are around $60-70 bucks whereas the one I need is in the $230 range?
Please tell me I'm mistaken.
Thanks in advance!
Old 12-16-2012, 10:08 AM
apexi_rsx's Avatar
Default Re: 1997 Honda Civic EX VTEC Oil Pan ?
only differance between the y7/y8 oil pan is the y8 is aluminum and the y7 is steel. you can use a y7 with no problems.
Old 12-16-2012, 10:34 AM
Sweet, that's great news! I thought I had read the bolt holes were different. But then again, I've read so much I started to get mixed up. lol And I also didn't realize it was a vtec when I was initially looking.
I plan on using this to help me out.
Hopefully it's not too far off.
I'll be back in a week or so after everthing arrives and I start the project. Thanks for replying.
Old 12-16-2012, 10:53 AM
Technical Hero
HondaPartsHero's Avatar
They also use different gaskets as well
Old 12-16-2012, 11:03 AM
So you're saying the oil pan is interchangable between the base models and the EX vtec, but the gasket is different?
Old 12-16-2012, 11:13 AM
Technical Hero
yes
Old 12-19-2012, 03:27 PM
Before I click the order button, I just want to make sure ... get the gasket that matches the y8 (my car) or the y7 (the new oil pan)?
Thanks
Old 12-19-2012, 04:19 PM
Technical Hero
Blocks are identical so match the oil pan
Old 12-19-2012, 07:45 PM
apexi_rsx's Avatar
y7 oil pan + y7 oil pan gasket
Old 12-19-2012, 07:54 PM
Got it. Thanks again guys.
IHEARTMYHONDA91
08-24-2008 08:57 AM
white_crx_guy
04-04-2007 03:44 PM
RacerBoy
06-17-2003 05:44 AM
rjardy
11-24-2002 11:00 AM
Quick Reply: 1997 Honda Civic EX VTEC Oil Pan ?
