1997 Civic LX won't start
I drove the car to lunch and came out to start the car and it did not crank at all. When I turned the key on everything worked but the car did not want to turn over. Luckily I was on a incline so I was able to pop start. Could this be a relay?
Re: 1997 Civic LX won't start
Dead battery?
Rubber stopper at top of clutch pedal fall out? http://i639.photobucket.com/albums/u...cture_5078.jpg |
Definetely not the battery, but I did just have to replace the plastic piece for my brakes so that may it.
Yep, it's for sure that piece there. How in the **** do I fix that?
Buy a new stopper or hot glue a coin over the hole.
It seems very difficult to try and even get up in there. I have a stopper that I use that fits perfect it's just a matter of getting up in there.
Originally Posted by pintobean11
(Post 45989867)
Originally Posted by grumblemarc
(Post 45989900)
Pull the seat back and get on your back. Easy. Getting back up. Not so easy.
God, that was such a bitch to work on. I rigged the shlt out of it with 3 zip ties. Let's see how long this holds up.
I just repaired my 94 Del Sol today. Civic should be similar. It wasn't that bad. I got the pedal stopper from the Honda dealer for 50 cents a piece. I have now replaced all 3 (1 that controls starter signal, 1 that controls cruise control & the brake light). By far this was the worst one. Tried to get to it without pulling the clutch pedal assembly, but I couldn't get to it with my finger. I ended up pulling clutch pedal assembly. Took me about 2 hours being an Old man of 52. Laying on your back is a pain.
Now, for how I did it. First thing remove the driver's seat and then the plastic kick panel under the steering wheel. Then remove the cotter pin and 1/4" pin holding clevis on the clutch master cylinder. Remove the 2 nuts with a 12mm socket that hold the clutch master cylinder to firewall and push it back into engine compartment. The one you can't see, I removed with a 1/4" socket set/12mm. Next thing is to remove Upper bolt above clutch switches. You have to strain to see it, but it can be removed with a 12mm socket and long extension. When it drops down, disconnect the two plugs on the switches & remove from car. You will see the hole where the stopper needs to be installed. If you have any more questions, you can email me at teddyg@cox.net I will post pictures as soon as I figure it out. |
I have pictures, but can't figure out how to post. If you need them, email me.
Originally Posted by tgreyboy46
(Post 46155029)
