1997 Civic Cx+b18c swap.......... what A/C system will work?
Old 06-14-2003, 12:41 PM
Halo's Avatar
Default 1997 Civic Cx+b18c swap.......... what A/C system will work?
I already searched
https://honda-tech.com/zerothread?id=217655
but still have some questions.
I have a 97 Cx hatch with b18c swap, will a A/C set-up from a 00 Si bolt right up? Do I need a 00 si a/c mount.
Thanks in advance yO!
Old 06-14-2003, 12:57 PM
Dr. EKology's Avatar
Default Re: 1997 Civic Cx+b18c swap.......... what A/C system will work? (Halo)
You're gonna need every single A/C part off that 00 Si assuming that your car came from the factory without A/C. If it did, you can re-use all of the origina components including the compressor, the only thing that you will need is a new A/C bracket. I'm pretty sure the 00 Si A/C bracket will work, i think its the same as the Del Sol. Good luck y0!
Old 06-14-2003, 01:01 PM
Halo's Avatar
Default Re: 1997 Civic Cx+b18c swap.......... what A/C system will work? (EKology)
my car didn't come with a/c do you know if the 00 si a/c lines line up with the blower in the glovebox (behind the battery?)
Old 06-14-2003, 01:07 PM
EK MONEY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Halo &raquo;</TD></TR><TR><TD CLASS="quote">my car didn't come with a/c do you know if the 00 si a/c lines line up with the blower in the glovebox (behind the battery?) </TD></TR></TABLE>
yes
Old 06-14-2003, 01:12 PM
Halo's Avatar
Default Re: 1997 Civic Cx+b18c swap.......... what A/C system will work? (Peagreenhatch)
I just looked behind the glove box and it looks like its prewired for a/c, so basically hook up lines, compressor and condensor then it should work right? The A/c buton in the cabin is covered, with a plastic cover from the factory does that cover just come off?
Old 06-14-2003, 01:29 PM
Who Said's Avatar
good luck
Old 06-14-2003, 01:31 PM
thinkbrianthink bu's Avatar
Is this the infamous camo'd civic?
Old 06-15-2003, 12:43 PM
Halo's Avatar
Default Re: (thinkbrianthink v2)
yes sir, I am changing the color soon to black on black camo with red panasports and limo tint
Old 06-15-2003, 12:47 PM
Halo's Avatar
Default Re: (Halo)
plus a/c!
Old 06-15-2003, 02:18 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Halo &raquo;</TD></TR><TR><TD CLASS="quote">I just looked behind the glove box and it looks like its prewired for a/c, so basically hook up lines, compressor and condensor then it should work right? The A/c buton in the cabin is covered, with a plastic cover from the factory does that cover just come off?</TD></TR></TABLE>
don't forget the evaporator. it's the thing under the dash where the ac lines connect to. for the a/c button there's a light under the cover, but no button. you'll need to get a button from somewhere.
Old 06-15-2003, 02:25 PM
JDMy0's Avatar
b18c1 or b18c5?
Old 06-16-2003, 11:37 AM
vladd's Avatar
Default Re: (JDMy0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMy0 &raquo;</TD></TR><TR><TD CLASS="quote">b18c1 or b18c5?</TD></TR></TABLE>
i don't think it'd make a difference.
beaterdriver
06-27-2004 12:05 PM
jdmsol
02-10-2003 10:38 AM
Quick Reply: 1997 Civic Cx+b18c swap.......... what A/C system will work?
