1996 Honda Civic DX engine won't start
Old 05-01-2012, 07:31 PM
sSandstorm's Avatar
Icon2 1996 Honda Civic DX engine won't start
I just replaced the clutch/flywheel, and now the car won't start. It turns over, and the engine shakes, but there isn't any ignition (that i can tell). I just replaced the starter today, so I doubt that that could be the problem. In the past, I've had the check engine light come on before, saying a cylinder misfire. I was just looking for help/advice on what to do next.
Old 05-01-2012, 11:06 PM
EK9
Dc4LsTeG's Avatar
Default Re: 1996 Honda Civic DX engine won't start
Check engine grounds
Old 05-02-2012, 09:52 AM
sSandstorm's Avatar
Checked the engine grounds, they seem fine. Also, I started it up a couple nights ago, but the spark plugs were in the wrong firing order. Could this have damaged the engine?
Old 05-02-2012, 10:50 AM
Mr. EG's Avatar
It would not have damaged the engine. Just re-correct the firing order. Give us a little more information on the car.
Old 05-02-2012, 12:54 PM
sSandstorm's Avatar
I have since re-corrected the firing order. I believe everything is stock. The car was working fine before I replaced the clutch, the clutch was just obviously worn down and was not shifting correctly. Give me a few minutes and i'll upload some pictures of the engine bay, you may be able to see something i can't.
Old 05-02-2012, 12:58 PM
EK9
Dc4LsTeG's Avatar
Id still recheck your Trans ground and thermostat ground. Also maybe recheck the connection for the starter
Old 05-02-2012, 01:03 PM
sSandstorm's Avatar
http://imgur.com/a/1neTP Here you go. Just ask if you need a better picture of anything, or more information.
Old 05-02-2012, 02:19 PM
sSandstorm's Avatar
Oh, and yeah, I rechecked the Trans ground and thermostat ground, plus the starter.
Old 05-02-2012, 04:58 PM
sSandstorm's Avatar
Also, some more info, it's got about 181k miles, the spark plugs were replaced FAIRLY recently, (i think about 15-20k miles), but the wires have never been replaced in the ~60k miles we've had it.
Old 05-02-2012, 07:54 PM
beecee18's Avatar
Spark?
Fuel pressure?
have these been checked?
Old 05-02-2012, 08:26 PM
southie's civic's Avatar
is the battery dead ?
Old 05-03-2012, 07:52 AM
sSandstorm's Avatar
The battery isn't dead (Even if it is, we've tried jump starting it). I am not sure how to check fuel pressure, but ill check the spark plugs later today.
Old 05-03-2012, 01:43 PM
RuckinEK
Guest
Posts: n/a
I would double check all connectors, especially the ones underneath the distributor. Any check engine light?
Old 05-03-2012, 01:52 PM
sSandstorm's Avatar
No, no check engine light.
Old 05-03-2012, 02:20 PM
FAMz_DOMANi_MB4's Avatar
check ur main relay and fuses
Old 05-03-2012, 02:53 PM
sSandstorm's Avatar
The spark plug wires are good.
Old 05-03-2012, 03:16 PM
sSandstorm's Avatar
Here http://youtu.be/GLlHnJabjPY is a short video I took showing what happens when i try to start the engine.
Old 05-03-2012, 03:28 PM
check ur ecu, main relay, this one box under the dash next to the steering column, check ur main relay fuse
sounds like something not plug in all thee way
Old 05-03-2012, 09:35 PM
1990Civicxdgg12's Avatar
I agree with the top guy. Check your relays. It might be that.
Old 05-03-2012, 09:56 PM
cloudconnected85's Avatar
Your plug wires appear to be in the wrong order in the video. I may be seeing things but it looks like your number 4 wire is connected to the number 3 terminal on the dizzy.
Old 05-04-2012, 10:48 AM
^^^ i agree the wires all look like they r one to the right off
Old 05-04-2012, 12:04 PM
sSandstorm's Avatar
Yay! It was the spark plugs! But now, it's idling really high, and the Check Engine light came on with "p0141", saying that it was a sensor 1 bank 2. When it starts, it starts to about 1400 rpm, then goes to 1500 rpm and stays there. I'll have a video in about an hour (when it is finished uploading)
Old 05-04-2012, 12:44 PM
sSandstorm's Avatar
http://youtu.be/DHLvkE36Jqc
Old 05-04-2012, 01:14 PM
what kind of fuel you running??
Quick Reply: 1996 Honda Civic DX engine won't start
