1996 civic dx - smoke(blue) like crazy when rev
Old 11-03-2010, 04:26 PM
hymn's Avatar
Default 1996 civic dx - smoke(blue) like crazy when rev
HELLO ALL
i have a 1996 civic dx 5 sp no power steering and it been sitting for a while
and my issue is when i start up the car it run fine beside a bit of smoke coming out of the tail pipe. But after 5-10 min i start driving it or rev it at idle, smoke fly out like crazy. what can be the cause of this? i was told it might just need a simply maintenance since it was sitting so long. im just hoping it not the ring as some1 told me
any input would be useful
THANKYOU
Old 11-03-2010, 04:58 PM
ben8ny's Avatar
Default Re: 1996 civic dx - smoke(blue) like crazy when rev
rings could be siezed in the pistons depending on how many miles are on the engine you might be best to invest in a rebuild.
Old 11-03-2010, 05:04 PM
hymn's Avatar
engine have 135xxx miles on it. i just did some research and found out that the ring can be test by doing a compression test so im give that a shot. Also found out that it could be a valve seals. is there anyway to check/test this?
was also told " rings smoke all the time and valve seals on start up only " true or false?
Old 11-03-2010, 05:08 PM
ben8ny's Avatar
usually when valve seals leak its only during start up for a few seconds.try the compression test right down your numbers and then do it again on all four cylinder and drop a cap of transmission fluid down each cylinder. if the numbers change drastically then you know your rings are bad.
jc2801
27
08-25-2015 08:22 PM
hondamatt89
03-17-2015 11:19 AM
marco562
10
11-19-2012 10:59 AM
1sikhatch
04-26-2007 02:22 PM
vxturbociv
07-23-2006 06:27 PM
Quick Reply: 1996 civic dx - smoke(blue) like crazy when rev
