1995 GSR.....
1995 GSR.....
1995 JDM GSR, usdm gsr wiring harness, jdm ecu
1993 civic cx....
no check lights....
car starts and idles fine....
but when i hit the gas and rev it, it will only let me go to 3k at the most...its like its hitting the rev limiter...
im getting the understanding that i need to not use the map sensor on the throttle body and use something else????
help...whats going on with my car..??
***it works pics towards the bottom..
Modified by degooser at 12:00 AM 10/16/2003
1993 civic cx....
no check lights....
Re: 1995 GSR..... (degooser)
sounds like incorrect TPS settings. did you replace the TPS on the throttle body?
make sure the TPS voltage setting is at .5 volts at idle and 4.5 volts at WOT.
Re: 1995 GSR..... (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">sounds like incorrect TPS settings. did you replace the TPS on the throttle body?
make sure the TPS voltage setting is at .5 volts at idle and 4.5 volts at WOT.</TD></TR></TABLE>
did not replace it...
when my coupe had incorrect settings it ran real real rich...this does not...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by degooser »</TD></TR><TR><TD CLASS="quote">1995 JDM GSR, usdm gsr wiring harness, jdm ecu
1993 civic cx....
no check lights....
help...whats going on with my car..??</TD></TR></TABLE>
come on guys any ideas?
1993 civic cx....
no check lights....
happened to me but it was the ecu... i wired everything up correctly and it wouldnt let me rev more than 4k.. i swapped ecu adn it worked fine. goodluck
Re: 1995 GSR..... (milo)
its called LIMP MODE...
are you sure you're check engine light isnt on???
check the cluster to see if the bulb was removed or broken...
then check for cels
then check for cels
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milo »</TD></TR><TR><TD CLASS="quote">happened to me but it was the ecu... i wired everything up correctly and it wouldnt let me rev more than 4k.. i swapped ecu adn it worked fine. goodluck</TD></TR></TABLE>
tried 3 different ecu's
jdm p72, usdm p72, and stock cx ecu...
forgot to add that its not smooth when it gets to 3.5k....kinda bogs out..
Re: 1995 GSR..... (pennies_hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie »</TD></TR><TR><TD CLASS="quote">its called LIMP MODE...
then check for cels </TD></TR></TABLE>
200% positive that its working threw a code 21..but got rid of that quickly...
one thing is that we changed out the fuel pump to a napa one...
its getting 40 psi before we start it and 90 when the car is idling..
had the same problem workin on my car......this was my story.....timing belt slipped after i installed it......re-adjusted the belt ......
and i forgot to plug in the IAB solinoid .....replaced head gasket...
double check all your vacuum lines
good luck
good luck
Re: (mr_timluu)
thanks ill recheck that..cause im sure when i rechecked everything for the 20 billionth time i might have missed something...
ill keep my fingers crossed thanks for the help..
1993 civic cx....
no check lights....
1993 civic cx....
no check lights....
Re: 1995 GSR..... (axhandler)
so its a jdm gsr going into a 93 cx...
it didnt have a line going from the fuel rail to the fuel filter...
so i used the stock cx line and cap at the end of the rail...
little did i know that it is a little different for the gsr...
we just changed out the line to an integra one and we also use a cap from an integra...
boom problem solved...
runs like a champ...!!!
Yeeaaahhh, did you get the memo? You see, we're putting cover sheets on all the TPS reports now. I'll go ahead and make sure you get another copy of that memo.
Re: 1995 GSR..... (BrewerHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewerHatch »</TD></TR><TR><TD CLASS="quote">
Yeeaaahhh, did you get the memo? You see, we're putting cover sheets on all the TPS reports now. I'll go ahead and make sure you get another copy of that memo.</TD></TR></TABLE>
i dont get it?
i dont get it?
aasaa666
06-29-2008 08:13 PM
