1995 dx radio/cig lighter dont work
so i bought this car with no center counsel i installed all new parts and wired in a pioneer stereo but nothings working, stereo or cig lighter. the fuse is good the hot wire has power but nothing works. the guy before me wired a sunpro tach(it works when i turn in acc) to the option E socket and im wondering if a relay or something is supposed to be there instead??? he fuked around in the fuse box and lost the map so i looked one up and installed all that were missing but i cant find anything bout option E.
Re: 1995 dx radio/cig lighter dont work
yes all my fuses are good but theres an option E socket thats linked to the fuse for the radio and idk if there is supposed to be a relay there
The Grumpiest
IDK what you keep talking about when you refer to this Option E socket. I don't have the fusebox memorized nor do I want to search for it. The socket for a relay looks NOTHING like the socket for a fuse.
And how did you check the fuses? IDK how many times people come in here and claim they checked all the fuses and it turns out to be a blown fuse.
ok well it dont look like a fuse socket and everything i see online says they are linked but nothing says if something is supposed to go there or not so idk.the tach i have is wired to tha socket ad it turns on when i turn the key.
and i actually took each individual fuse out and inspected them. and the power wire has power cuz when i accidently touched some metal in the dash with it it sparked and blew the fuse. i did replace the fuse after this.
Test them. Don't just look at them.
Hey I have the same car and currently trying to solve this problem. I was driving one day n I stopped at a gas station then I realized my stereo was not turning on, later I also discovered that the cigarette lighter was not working as well. I have checked all the fuses under the hood and below the steering wheel like five times already, I also got a new main relay and changed the computer if that's related at all(had another problem). When I first noticed that my car stereo was not working I did find the stereo fuse blown so I changed it but nothing happened. I tested my stereo in a friends car in case it was not working but it did turn on, so I was wondering what the f*** is wrong??? I'm planning to strip the dashboard apart and trace the power and ground cables, maybe I find something loose so if you found a solution it would really help a lot
