1994 Honda Civic Mods
#26
The Grumpiest
Re: 1994 Honda Civic Mods
Sorry but that blue paint job is pretty terrible. You didn't properly prep the surfaces at all and it's downright sloppy. I would be ashamed to post that up but hey, it's your car.
#28
How was it not prepped properly, I'm open to any sort of criticism as long as it has reason. I prepped as best I could, grinding down both drums and both calipers with an angle grinder with a special wire brush attachment then proceeding to a small wire brush to get into nooks and crannys and a light sand. Then cleaning with a varsol equivalent to remove grease, wax, etc. After wiping down I masked the corners and everything else and personally am very happy with the end result.
#29
The Grumpiest
I can see the spots where you had some kind of contaminant on the drum right before you painted it. You didn't clean it thoroughly. That much is obvious. Probably oil/grease/dirt. The caliper has paint on the rubber parts and on the pads! You even got it on the damn rotors! It looks like Stevie Wonder did the painting.
#31
#37
seriously need some help here, on my purple civic its a 93 si and when i have the headlights off the hazards function but make the instrument panel flash as well and when i put the right of left signal light on it makes the hazard flash. when i turn the headlights on the signals do nothing and the hazard lights come on and flash with the instrument panel?????????? checked all of the fuses and disconnected the hazard and dimmer switch and that didn't help
#41
Love the valve cover that looks sick, might even try that, keep me posted cause im wondering how itll stand up to the heat. Halo lights look good but are def not original, I like them though. Glad you didnt paint the hood and lid black cause that's also very common but I wana see how the clear coated metal turned out, couldnt find a pic of it.
#43
Would have just painted the calipers black but, hey what ever floats your boat.
The painted valve cover seems pointless if you don't bother to clean the engine bay first. I'd clean it up with some degreaser and it will make a huge difference.
Muuurph
05-10-2009 02:20 PM
abmerop18
11-01-2005 07:08 AM
