1993 LED Flasher Relay ?
Car 1993 Honda Civic Si
I am looking to replace the turn signal and other lights with LEDs, I have already done the headlights and I have been happy with the results My car takes the following turn signal bulbs Front Turn Signal Light Bulb: 3496 Rear Turn Signal Light Bulb: 1156 https://honda-tech.com/how-tos/a/hon...e-chart-378237 My question is, has anybody found hyper flash fixing relay that will plug into the 92-95 civics without being modified or do I just need to get one and make extensions? Also anybody have a recommendation on a brand model of LEDs for the turn signals? Looking for Amber. Here is a pic of what I think is the rely from my car. https://cimg5.ibsrv.net/gimg/honda-t...ffebbbc7ae.jpg Stock Flasher Relay 92 -95 This is what I have been finding on amazon. But they don't seem to fit in the stock fuse box without being modded. |
Re: 1993 LED Flasher Relay ?
This is what I bought for my sisters integra, should be the same fusebox.
Originally Posted by tony_2018
(Post 51949643)
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
not that big of a deal, now that you mentioned it I did have do something not so big of a deal to get it to work but it worked.
How goes your project? Haven't see you post in a while. |
When I installed an LED flasher on my 94 Sedan, i remember having to trim down the "walls" around the relay's spot on the fuse panel. Wasn't a huge deal, and never fell out. I'm planning on doing the same thing to my hatch whenever I get the time.
As far as bulbs, I usually get everything through superbrightleds(dot)com. I've never had any issues with anything I've ever bought from them. |
(Post 51949659)
Originally Posted by LiteraCola
(Post 51949878)
As far as bulbs, I usually get everything through superbrightleds(dot)com. I've never had any issues with anything I've ever bought from them. I will check superbrightleds, but I usually amazon prime everything lol |
find a 9003 male plug and just crimp spade connectors on it.
(Post 51950589)
Cut the cover off the led relay. Plastidip the exposed externals.
Done. |
Originally Posted by egsleepercivic
(Post 51950666)
Are they the same ? I found these which is basically what I was going to make
https://www.amazon.com/Audak-Ceramic...a-597642046066 |
(Post 51950666)
https://www.amazon.com/Audak-Ceramic...a-597642046066 also, sorry if im not supposed to reply to older forums..new here. |
