Throwing 2 codes
Old 02-15-2008, 12:04 PM
Civicse's Avatar
Default Throwing 2 codes
I have cels for both primary 02(1) and random misfire in cylinder 1(71). My car shutters in low rpms, but as soon as i get above 3k it runs smooth. Any ideas? plugs cap, wires and rotor are all no more than a year old.
Old 02-15-2008, 12:07 PM
Resident Gearhead
BryanM.'s Avatar
Default Re: Throwing 2 codes (Civicse)
Do an ignition tune up anyway, replace the O2 sensor and report back.
Old 02-15-2008, 12:34 PM
Civicse's Avatar
Default Re: Throwing 2 codes (mcvtec)
You mean raplace everything i listed? I don't think so. I'll replace the plugs and see what happens. I took one out a few days ago and it was kind of off white colour. 02 sensor is like 250 bucks. I'll have it tested before i replace it.
Old 02-15-2008, 01:18 PM
Resident Gearhead
BryanM.'s Avatar
What car and motor do you have?
Old 02-15-2008, 01:47 PM
Civicse's Avatar
2000 civicdx d16y7. its been shuttering in lower rpms for a while now. but it only did it every once and a while, but the last 2 days it does it in every gear, and then today the CEL started blinking and then just stayed on. When i had my emissions done a little while ago, the guy said i barely passed. Can the 02 sensor cause a misfire?
Old 02-15-2008, 03:50 PM
instrument's Avatar
everytime that's happened to me its been fuel related.
and trust me, the sputtering/misfiring posts when you search go on forever...trouble shooting it can be a pain.
have you visually checked your 02 to see if it may be damaged?
Old 02-15-2008, 04:17 PM
juda7's Avatar
Default Re: (instrument)
This may or may not help.
OBD-II Codes P0100 - P0199
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch A Circuit Malfunction
P0120 ETS MainThrottle Position Sensor Malfunction (Hyundai)
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0128 Range/Performance Problem In Thermostat(Acura)
P0128 ECT Below Thermostat Regulating Temperature(GM)
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
Old 02-15-2008, 04:41 PM
nautique196's Avatar
check your fuel pressure if you can. maybe a new fuel filter would do it. you would think if it was starving for fuel down low, it would get even worse up top. if it was way leaned out maybe the ecu would throw the 02 code, bc the 02 wasnt switching.
Old 02-15-2008, 04:43 PM
Default Re: Throwing 2 codes (nautique196)
did u do an ignition coil. my car needs one of them.
Old 07-24-2011, 04:36 PM
goldenchild707's Avatar
I know this thread is years old but i had the same problem and also a code for cylinder position sensor. i found a thread that tells you how to fix this. behind the intake manifold on you y7 sumtimes y8 too theres two big plugs disconnect the blue plug and youll see that your wiring is cut or frayed.(this will cause all sorts of crap on our hondas) i had the stuff mentioned above and speedo problems so try looking at the BLUE plug wiring and tape it back up after that you should be cool
Ed 341
07-17-2006 06:24 PM
Jorsher
05-02-2006 05:09 PM
96lewd
01-23-2005 08:44 PM
SleepnCiViC
18
12-08-2003 08:51 AM
Quick Reply: Throwing 2 codes
