1993 Civic- Leaky Clutch Slave Cylinder -I think-
I noticed a leak around what I think is the clutch slave cylinder. If this isn't the slave cylinder what is it? Is it easy to repair?
Re: 1993 Civic- Leaky Clutch Slave Cylinder -I think-
slave cyl doesnt take long to fix and it cheap. try and replace it then see if the leak is still there
the seals wore out. i think its like 20 bucks here at napa.
If your wondering why it would wear out think about how many times over the 17 years ( assuming its original) it has been applied pressure!
Okay so this is the slave cylinder. Good to know so I can get the right parts from Napa. Is there any how-to advice for this project that you guys want to share?
Is there anyway to adjust the clutch? I'm not sure what's it's called, but isn't there something that controls the clutch peddle that can be adjusted which will make it feel stiffer? The car has 320k miles on it with the original clutch. It's not slipping yet, however it engages when the peddle is almost all the way out.
I looked around the clutch peddle and there seems to be a screw that I can adjust that has a spring loaded thing that pops out.
Any ideas?
Any ideas?
Seagull Management
MasterLink4253
06-09-2014 07:22 AM
s1ngle
13
09-21-2005 12:01 PM
