1992 Civic SiRII - S Brakes and Suspension
Hello,
I just recently got back into the import world but looking to go about things a bit different this go around. I am looking to do more track events and autoX. Always wanting a RHD car I ended up purchasing a 1992 Civic SiRII-S. With that said I need to purchase new front suspension and brakes. Can some please give me some insight as to which USDM parts cross over to my car. I have heard that 94 GSR brakes will work but what about upper and lower control arms? An information would be greatly appreciated.
Re: 1992 Civic SiRII - S Brakes and Suspension
suspension in the front is the same as USDM, shocks\springs
the brakes should already be the 10.4 inch rotors
If you wanted bigger calipers the 94-01 integra excluding type r calipers, should bolt up
For the rear, I believe the LCA are the same as type R and would require type r rear shocks
For the rear,I believe the LCA are the same as type R and would require type r rear shocks
For the rear,
could not have said it better myself (I have almost the exact setup on my hatch)
for others reading, the USDM versions came with the 9.3 rotors so the integra knuckels are needed to go with the 10.4 in brakes, the sir share the same fronts, rotors and calipers as the Del Sols with b16a's
there are some reports of USDM 94 si with ABS that had the 10" brakes from the factory, i personally can't confirm
Thanks for the help guys, I appreciate it. What can I get away with regarding upper control arms? In need to order new ones. 1992 Civic SI or Integra 94 and up?
