16x7 with 40mm offset, will it rub?
will 16x7, 40mm offset rub on a dunked EK? I have a chance to get some TSW Spirits for dirt cheap, anyone using the Spirits?
[Modified by Halo, 9:06 PM 12/7/2001]
New User
Re: 16x7 with 40mm offset, will it rub? (Halo)
if your car is dumped, i'd suggest getting your front and rear fenders shaved just to play it safe. if your car isn't that low, you should be cool running the 40 offset. also, what size tires are you using?
Re: 16x7 with 40mm offset, will it rub? (jdm ek)
Actually I use to have a set of 16x7 45mm Sparco Viper Fangs and that thing was slammed, never had any problems. Will 5mm make that big of a difference. The tire size I would run is 205/40 16 if I buy the Spirits. I want to avoid having to shave my fender, I just want it to tuck
7" wide and 40 offset 16inch wheels shouldn't rub. I've got 17x7"(205/40-17) with a 40 offset and 1.8 degrees neg. camber and the car is pretty low. It only rubs if the wheel is turned 3/4 to lock and over a curb. You should be fine.
Re: 16x7 with 40mm offset, will it rub? (jgale)
I have 16x7 wheels with a 40mm offset it's lowered maybe 2.25 in back and 2.5 in front and I have a progress camber kit and is doesn't rub at all, ever! F.Y.I 205/40-16
Halo
10-30-2004 10:07 AM
