15" Spoon Wheels + Legend Caliper Setup = Do I need A Spacer?
If so, how thick would i need it to be?
THanks.
THanks.
* B A N N E D *
1 Post
Re: 15" Spoon Wheels + Legend Caliper Setup = Do I need A Spacer? (integlspwr2k)
define legend caliper. 1 or 2 piston? what year Legend? what bracket and are ya gonna run the 23mm ITR redrilled rotor or the 28mm Legend rotor with the offset from the legend rotor, youd need a wheel spacer. im thinkin no cause the spoon caliper manages to fit under the spoon rim.
Re: 15" Spoon Wheels + Legend Caliper Setup = Do I need A Spacer? (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX »</TD></TR><TR><TD CLASS="quote">define legend caliper. 1 or 2 piston? what year Legend? what bracket and are ya gonna run the 23mm ITR redrilled rotor or the 28mm Legend rotor with the offset from the legend rotor, youd need a wheel spacer. im thinkin no cause the spoon caliper manages to fit under the spoon rim.</TD></TR></TABLE>
this it eh 2 piston legend caliper, the bracket im running is the legend caliper grinded down to fit the gsr knunckles.
i'm running the 28mm legend rotor.
* B A N N E D *
1 Post
OK the usual Legend brake setup on the Integra uses the 23T bracket and ITR rotors redrilled, cause Legend GS rotors are 28mm thick and the offset is different (shorter rotor.) With that offset, and the 28T and 2-pot GS calipers, id still think you may need em, but again, if the spoon calipers go on a ITR, id assume these would clear too, tho the ITR compared to your GSR means the ITR hub is 3mm taller, so theres a extra 3mm clearence the ITR has for its bracket, tho the rotor accomodated this.
Your gonna have to try it i guess.
i am running legend dual piston calipers on my ITR Brakes with Tons of wheels fits everything.. btw All 5x114.3
Rota Slips 15x7 +40
RH CP035 16x7 +45
Super advans 16x7.5 +38
Rota Jmags 15x7 +40
Jdm CTR's 15x6.5 +45
Usdm ITR GM 15x6.5 +45
Kosei K1's 15x7 +38
Kosei k1's 16x7.5 +43
JDM ITR's 16x7 +50
Black Racing Pro n1 16x7 +35
if that was any help.. and here goes a picture of my Slips with the Legend dual pistons Calipers
Rota Slips 15x7 +40
RH CP035 16x7 +45
Rota Jmags 15x7 +40
Kosei K1's 15x7 +38
JDM ITR's 16x7 +50
Todd00
11-15-2007 10:07 AM
